Ignitiondvd Hot Spots + Dyno Comp!, Friday The 1st @ R.e Customs
I find it odd that I made 50 rwkw less that what I have on several other occasions.
Maybe the strapping was wrong.......
117 mph at the end of the quarter says it all.
Your spot on, there is no way 200rwkw would get you 117mph... I think something is wrong here..
  • Replies 123
You illiterate or just an idiot?
FYI it made 243rwkw (previously 257rwkw on the same dyno) and was the most powerful RB25DET on the dyno that night....most powerful non GTR skyline too...
Who the f**k is this muppet? I simply asked a question. omg it made 14 less rwkw on the night.... dyno number queens.
I drove into the court at 7:30 to check the turnout. I was intending on coming but plans changed so I just drove by. Everyone standing their watched as I drove in, was pretty funny to see, everyone expecting me to pull over. Pity I couldnt stay.
Good turnout.. was only there for about an hour and a half, but enough to see everyone roll up (a couple of nice little ladies aswell) and the first few runs. Most surprising was everyones ability to park in a reasonable formation in that court. :laugh:
Some nice cars there, wish i was there long enough to stick mine up on the dyno. :D
Few figures were odd. If its any concilation my mates twin turbo legacy pulled 117awkw where it had previously made 184awkw on the same dyno. :D wierd
Get your mate to check his earlier (184kw) dyno sheet. On the below he will see that the intake temp meter was out of whack. Read something stupid like 186 degrees.
That is the reason it read so high previously. The intake temp sensor was playing up sometime ago which Ray unfortunately did not know about until after that vehicle was dynoed.
Also FYI. For strapping to cause lower readings, this is generally due to "over tighetning" on the straps. Most cars on the night were "very" lightly strapped. So should have no effect on low readings.
Most likely other dyno's are "happy" or mechanics using the intake temp sensor trick to boost figures.
At the end of the day, the best way to tell if the power is down, is by how it drives.
Cheers.
Cheers.
Sorry for sounding like a "n00b"... ...but what does all that stuff at the bottom mean???... ...I'm guessing "IT:23" means Intake Temp was 23ºC...
IT = inlet temperature
RT = reference temperature
RH = reference humidity
RP = reference pressure
TN = inertia setting
RR = ramp angle
PL = power loading
CK = check reference
That there is the JaR man.. and you are a f**k head :D
you having a sook because yours comes nowhere near that?
I was there all night, well i got there at 9pm. Scored a red bull, 4 gay Ignition DVD which i'll give them away soon.
Well, opinion is one thing, but why'd you "score" ie take four editions of your own free will if you don't like them? There are plenty of other people who missed out because others took as many as they could.
A little courtesy to us as we did organise the night with R.E and made an effort for the fans and people such as yourself.
I didn't get any DVDs, but I did get my car photographed a lot :D
Any chance of a "sleeper feature"
to be considered a sleeper your car must make more power than it looks like its capable of. Your car looks 300kw and makes 200kw :)
</stir>
RR = ramp angle
PL = power loading
Kewl... ...Thanks for that...
to be considered a sleeper your car must make more power than it looks like its capable of. Your car looks 300kw and makes 200kw :D
</stir>
Oh. PWNED as well. Pete gets points for having the sexy LED tail lights though. Winnar!
Nah, problem is the fuel pump issue is sorted.
I'll be taking the beast to Benno's on the morning of the SAU dyno day and we'll have some fun.
oh yeah, bring on some 100 octane for that day too :D
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
