I have to say something here. Took a couple of hours yesterday to read the thread for start to finish :rofl:
Yes the GTR is a racebred car. Yes the Supra is not a racebred car. The GTR is compared to Porsches. The first time I saw a Supra in a magazine was in Wheels and they were comparing a DB7 to a Supra. The Supra is a GT car. Grand Tourer. How good a GT car it is, is a different matter. I like it. If you're too big to be comfortable in one, buy a Falcon or Commodore.
Niko
And as for the fella who said that the Supra is a Grand Tourer and the Skyline is not just what do you think the GT stands for in GTR? (Gran Turismo/ Grand Touring)
:down:
If you are referring to me with your comment, then you haven't even read my post. I never mentioned that the Skyline is not a GT car.
  • Replies 312
Posted Images
sorry, but if i had to pick 1 import that sux balls... it'd be a soarer...
even as a boat it'd still be ugly, and not just ugly... i'm talkin Joseph Merrick ugly! (even wif da sick chromies)
I believe the supra's (and soarer etc) biggest downfall is that the back end is so light and they are RWD only. Very difficult to get (and maintain) traction.
If only toyota put a 2JZ into something with AWD...that also looked as good as the supra does. oh well.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
