if it further helps ontop of boosted_r32's comment... i had a set of xforce extractors on my civic... and they fit perfectly.
Everything was perfect from O2 sensor location to original bracket locations.
and the difference they made... well worth money spent! im sure the dumps are gonna be just as good!
How hard is it to fit dump pipes yourself?? Whats involved?
Hoist
Lots of tools
Full day if you've never done it before
You gotta pull the rear dump etc off, then the rear turbo, then the front dump, put the dump on and re-assemble.
You can do it on a trolley jack, but it takes forever as you have to go from over/under the motor on many occasions.
Simply put, if your not a good hands-on person, a GTR dump swap out is a workshop job as it’s a fair mongrel of a job.
Once you've done it a few times you can peg it back to a few hours, but you wont do it in a few hours off the bat IMO
Im about to put my turbos back on with X-force dumps. Thing is.. it doesnt look like my exhaust pipe from the dumps to the cat will line up with the x-force at all.
Anyone else have this prob?
Im pulling off stock turbs with stock dumps and the pipe is a 3-inch something or other. I assume its also stock
to r31 gagz, were you running stock or aftermarket dumps?, and are adj cam gears more worthwhile than cams?i want close to what you have on a safe tune...oh and were you using power fc d-jetro, or just normal? we got a good tuner here,and im about to buy an aftermarket ecu....
thanks.
Edited by nsta
  • 4 weeks later...
im currently changing my dump in my gtr as well. however i couldnt get it right. the problem is when i compare the stock front and rear dump pipe, they are in fact not the same shape. but the stainless pair i have just bought is in the same shape. the stainless pair is identical. does this sound right? or are they supposed to be different in shape (the aftermarket ones)? the problem im facing now is the rear dump pipe is in the way of the gearbox housing.
when i look closer to the stock manifold i can see that they are not the same too. is that right? if yes does that means im having this problem now becoz i put the rear manifold on the front and vise versa?
plz help guys. any info would be appreciated. thanks :)
well you are half right. dump pipes are different front to rear but the manifolds are the same. If both dump pipes are the same there is a problem.
I had a really crap set of ebay pipes recently that also fouled on the gearbox. very frustrating they were on and off about 5 times to be modified, grinding the end off studs, bashing the wastegate pipe to clear the rear intake etc etc.
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
