Hi,
I have a Stock R34 GT-R and I put 20L of Caltex Vortex Premium by accident (which has a octane rating of 95) when I should have filled with Vortex Premium 98. This happened because there was no Shell V-Power left at the Shell servo so I decided to use Caltex for the first time and I thought Vortex Premuim was their 98 octane rating fuel.
So my question is this, do I have to empty the fuel tank of all the current fuel ASAP to avoid damage or can I get away with using this fuel (not driving hard) until it runs out and then fill up with the 98 octane rating fuel.
Thanks,
Glen
https://www.sau.com.au/forums/topic/205557-fuel-for-r34-gt-r/
with the std ecu it has maps based on 98 RON fuel
now that the user has put in penis fuel (95 ron) the timing will be too advanced so it will combust without spark - detonate / knock
this in turn will tell the ECU its knocking (assuming stock ecu) and the ECU will drop the low octane map
its still bad for the engine and i wouldnt load it up on purpose with penis fuel in it
the stock ECU has no idea (or any ecu for that matter) what octane fuel is being used
all it does is watch the knock sensors for detonation, once it seems certain levels of detonation
it assumes penis fuel is in use and drops back to low octane maps, which basically have retarded timing on them
this makes the car not detonate as the timing is very relaxed and makes the car doughy and flat
yes so in summary
your options now that you have put penis fuel in the tank
1) drain the tank and put high octane in it
2) baby it around and then put high octane in once empty
3) use octane booster and baby it around a little - i would still avoid full loading it up
it will never detonate on light cruise / crusing at 100kmh in 5th or 6th
if its going to detonate with penis fuel, it will be when its ramping on boost or on full load
this is because the engine is under load, and has much more aggressive timing
I wouldn't use octane boost .. I'd rather not have that in my motor after seeing the dirty stains it left through my last GTR's head. Maybe its just cosmetic but even so.
The 34 GTR stock ECU will probably pull timing on you even when you are driving around normally. When I had even a slightly bad batch of 98 in my 34 it would pull timing quickly after driving for a little while and would leave it retarded until you switched the car off and back on. This happened more than once so i correlated the occasions to a particular servo and avoided that from then on.
Don't load it up and fill the tank with better fuel when you can next.
if u want to use octane booster...why not use snake oil, it will have better effects :P
http://au.youtube.com/watch?v=2jbcCr2ll3c
octane boosters do shit all. put that money into an extra 5ltrs of 98 :)
I dont know what you guys are talkin' bout. has anyone actually done it and had problems???? I assume it would if you are running a massive setup, but for basically stock applications it is fine. I have done it to trial different things to my car (I didn't drive it any different - still flogging the guts thru it) and it did nothing... Think... Its 3 octane different out of 95-98.
Don't be worried mate, if you want to be careful, just don't flog it too much. :(
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
