Spotted two nice Stags today on the way to the food and wine thing at Norwood. Red one on Main Nth near the Old Spot and a gorgeous Black RS 260 on Portrush at the Parade, very noice!!!
Spotted a rather clean looking red 32 in blackwood last nyte around 6.30. gave a wave do know if ya saw
Also had one of the new stags driving behind me yesterday arvo on south road was silver dont know if your on here or not.
spotted on me way home from the city this arvo;
a nice midnight purple 33 GTSt - assume it was one of the 40th anniversary models, had GTR wing and a badge on the upper rear pillar - on Hackney Rd
a yellow R34 GT-t with no spolier turning on Darley rd near the paradise interchange
and a wine red 33 GTSt with standard rims, p plater, on Newton Rd
spotted a few r33's on my way to work then back home again........mainly stock looking ones.......a couple black, a red one there is a silver r34 in a car yard on port rd that i havent seen there before...
Spotted, i think SapphireGraphics, in a white r34 heading out of Aldinga at around 6pm. Gave a wave and received a wave.
Yep it was me,,,spotted abe on his way home, got a wave ...lol
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
