Well i got off today which im stoked about. Wooooo. I didn't reply to your message Ryan coz i was being slack. Haha. And you are a prick too. LOL. Oh and damn do those rims look hot now. Mmmmmmm... I took the spacers out lol. What were they in there for anyway??? For looks or to stop rubbing???
you got it off. thats great to hear. im glad of that.
the spacers were in there on the front to stop the rubbing of the inside of the rims on the huge sway bars. the extra lock spacers caused that. with the 5mm spacers they dont rub just. rears they were in there to push the rears out to get the fitment i wanted without dialing the camber out to 0deg.
Got on the back of a mini skyline cruise last night on payneham road around 8.30pm.
1 - what looked like a maroon 32 and
2 - 34's, one white "p" plater, and the other yellow with nismo rear bar (couldn't see anything else).
drove behind for a bit - sounded crazy all the same exhaust note purring together! :P
spotted multiple s15's today. a black one with rego "L15A" on the way to and home from work, another black one turning onto main road boosted past me, and another white spec r parked out the front of work today :D
spotted a black 33 with a couple of girls pretending to drive it =P at noarlunga mccas,pizza hut, kfc lol
i keep seeing this old ooold lady getting around in a series 2 s14 around morphett vale lol
Lol the black 33 with a couple of girls pretending to drive it was mine >_< ... Always good to have some company while I'm delivering pizza's haha
spotted a silver 34 gtr @ mt lofty just before
minnnnnnnnnnnnnnnnnnnnt
Yeah that 34 was VERY nice.
Also spotted ripp3r and a few other 32's.
susrx7 a bit earlier in the night at houghton.
And plenty of cops around the suburbs being nice and friendly to absolutely everyone.
Edited by nicr4wks
SUSRX7 is one of my mates, Jason. Im guessing it was with a bunch of other cars, they sent me a SMS but my R32 is missing half its front end lol.
Yeah there was an old pulsar and a golf gti iirc, that rx7 seemed pretty gutsy and chucked some killer flames.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
