might I add:
To the P plate driver in the silver 31 that tailgated everyone from Gepps Cross to Elizabeth:
Tailgate me like that and I will be sure to hit the brakes and let ur unsecured 6x9"s decapitate you.
Keep bogans out of skylines. Go buy a commodore you dickhead.
/Rant.
just spotted andrew's (nightcrawler) car in the shop, getting some work done ;) nice car mate
Thanks mate! She is getting there .... John is fitting the factory style cruise control today for the long drive up to Loxton. I fitted the front lip yesterday (in my trademark rattle can satin black), and put in the Alpine 12" in box and 1000W amp in yesterday too, so now she has some very nice sounds, with the Tarantula 6.5 splits I had put in a few weeks back :)
Another reason to not tailgate people (apart from the fact it is just retarded), is that speed cameras now have the capability to do you for not leaving an adequate following distance - in a 60 zone you have to be a full 2.8 seconds behind the car in front of you, otherwise they will nab you for a high $200s fine - one of the guys from Morpowa was done the other week.
spotted a whiteish cream 4door 34, with 34 gtr rims on goodwood road, then pull into bp. awesome brunette driver :)
and spotted mr dstroy going through kenihans/panalatinga intersection at about 8.20pm. Couldnt miss it with the numbers on the doors!
You. Are. Joking? f**king assholes
Spotted a nice maroon R33 with silver advanti rims parked just off Jetty rd this arvo
If it had a nismo 400R front bar sides and a D wing and a veilside rear bar this would be me. :) They were sparco racing rims tho haha.
Is yours a yellow 33 with white rims?
Pretty sure i spotted 'Black 33' going past super cheap earlier on. Sorry I pulled out so slowly, one of the car parks pulled my front bar half off..
Haha yeah that was me, came around the corner and thought F*#k me whats going on when a skyline is going so slow lol...
Hope its not too bad.
Also later on spotted a black series 2 stag turning from diagonal road onto sturt road, female driver
On way back from marion spotted a silver 33 with the led rear lights, dont like the look of them, the red led ones arent so bad
I think it's a good thing they're finally going to crack down on idiots who tailgate.
I usually solve the problem by slowing right down anyhow, that'll get rid of a tailgater!!
Spotted far to many Police up in the Reynella area today. Had my car in getting a wheel balance and had an underover sitting across the road waiting. lol. I think my car scared him off coz as soon as it came off the hoist, he looked over and stared for a bit then did a U turn and ran away. Probably coz it's legal height now.
legal height???
f*k me i havent seen it like that since i complianced it. didnt like it then either.
how does the front wheels sit inside the guards???
i know the rears can be adjusted in but front or have you put in adjustable arms??
Yeah, I agree, but what's next? Fart-o-meters to fine me if I drop one that's too loud and smelly?
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
