black 32 with some kind of custom plate on south road darlington, at 5.30pm, and a silver stag with a small kit following behind him
spotted exit 33 on daws road, at about 8.20am.
spotted a black R33 FAKE GTR on pt wakefield road tonight
GTR grille, wing and side skirt. yet no wide guards or RB26.
nice work dude. maybe next time get the real thing?
Also spotted near the intersection of Pt Wakefield and Montaguea guy in a broken down Silver 33 - hope you got it all sorted dude. You looked pretty devo.
Spotted this guy today while leaving tafe, awesome car man!! :down::)
Also on way home 33 with widebody
Grey 32
Black 34GTT on flagstaff road, blonde driving i think, didnt get pic of that one
Silly boy
We tried :down:
We can all laugh when he replaces it in a few months...
Yes you did try, i took your comments and opinions to heart as well as what Jim Berry said, yes you can laugh at me if/when it does fail...BUT, i shall be holding my tuner responsible, as he suggested it, and said they are just as good as any other.
...Spotted a Red Stagea this morning on South Road, heading South in the Aldinga area.
Spotted the most "JDM" looking R32 GTSt Ive ever seen on Main North Road at Elizabeth about 4.15 this afternoon. Gunmetal grey, big fitment wheels and a bodykit that Ive never seen before. Didnt sound "normal" either :) Top work man :down:
should have bought a landcruiser :rofl:
hey craig, special rate for you :) double hehe
Grey 32
the middle one u posted (the primer 33) is marko i reckon (tx3_90)
Spotted this guy today while leaving tafe, awesome car man!! ;):)
Grey 32
i seen the owner of that fake gtr.. the guy went to autobarn and asked for spark plugs for a "gtr with an rb25".. was gonna say something but kept quiet. haha
absolutly hate them supra wings.
I will say that he drove it like it was a GTR :) lol
Well done to the guy who sold him the RB25 GTR, bit of research next time??
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
