Forgot to mention ...
Spotted MISS VQ in her shitbox Commonwhore last weekend ... sitting up my arse down Main North Road. Then almost hitting my Stagea trying to run up the inside of me on a 2 lane into 1 merge section of road. THEN almost hitting me whilst tailgating me again when I had to turn down a mate's street. BUt clearly she's tough, having given me the finger after she was safely up the road and I couldn't turn around. Stupid thing to do when the owner sticks that thing in car shows regularly. See you soon. :)
Also spotted Matty last night down Brighton Road. :)
Seriously, how dumb can some people get??! :)
Dohmar, if you buy the plate for $1000, she throws the car in for free!!!!!
what a waste of $1000... thats at least a few decent mods right there...
-D
spotted my r33 outside my bedroom window lol
also spotted a damn nice r34 grt at hollywood car wash. number plate "up 4 it" and it just happens to be for sale for 82 grand on carsales lol take a look at it guys
spotted a silver r33 series 2 on OG road at around 11:45pm sat nite.. plates were ecr33.. sounded nd looked sweet
That's my mate Andrew. Very nice car, clean inside and out and goes pretty damned well :blush:
black r33 GTR on christies esply last night
a flock of R31,S13,180 doing burnouts/drifts about 5pm last night in lonsdale just near grand nissan wreckers st.off osulleys beach rd, police have been called with photos on a Biz CCTV video camera and rego plates turned in , I was at a store who's owner was on the phone with the police turning you in for blatant hooning
sadly I think I know a few of you from R31 club , you guys really should have taken your "10000hp" on wet roads burn outs to the track
you give us a bad rep!!!!!!
miss vq once tried to run me off the road in my old car a few months back. i was heading towards her, and she realised i was actually accelerating, then she drove up the curb. it brang the lols.
spotted a couple of s2 stageas on south road near the underpass one white with a full kit not sure what it was but looked tough and had mess wheels i think there stag stockies and another white 1 but it was stock looking
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
