or missile launchers are for the Military use only!
i was looking at buying a ferret armoured car once
and i saw one with a 2x2 set of AA missiles mounted instead of the typical 50cal radial
was only 18,000 british pounds... back in 2001...
tho lately i saw a british challenger main battle tank for sale on a military collectables forum for 24,000 british pounds (this year)...108mm cannon intact
skaifey i just want one
-D
After skidding all day at Mallala last weekend I can't go back. I couldn't ever drive my GT-R like I drive my Sil and its SO MUCH FUN - Having said that, it was a tuff streeter for what I wanted. Wonder what that kent was buying from JIS lol. Car didn't need anything :)
You never drove the GT-R in anger so you can't comment :)
geez wayne, u make that car sound like it had 5000 kms on it and had been garaged for the past 15yrs, mine next to yours must be the next summernats grand champion...
LOL Jake gtfo hahaha.
______
Getting a pair of bride brix's - Yeeeah, not bad I spose lol
white stag rs4
maroon stag rs4 on black wheels
pink 31 kitted up like something you would get out of a cereal box :P , but appeared to be bone stocker apart from that
mint as silver 33gtr
silver 33gtst series 1 with a duck wing
all at reloaded (st clair rec) last night/today
pink 31 kitted up like something you would get out of a cereal box :banana: , but appeared to be bone stocker apart from that
coupe? fair sure its built if its the one im thinking.
silver r34 near the airport
black gtt s2 with gold wheels no wing in ikea, GTR badge in the front grill,wtf
white r33,similar to abes near christies beach
think it was tangles in the stag, in MV
R33 "atina 33" parked at a house in seaford
dark silver lotus elise, doing about 90+ on brighton rd heading towards seacliff
red 34 gtt boosting down my street. moron
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
