I always see a grey R33 GTR with lots of nismo badges in the Findon shopping center carpark. Has vented front-guards and the rims don't quite match up with the guards, but otherwise seems fairly tidy.
Guessing someone on here?
Yeah I see that 33 regularly also Jenna. So many nit wits in that carpark I've seen some very questionable displays of parking haha!
On edge that could have been me you spotted grange rd I turned onto south rd. Just got the car back with my greddy induction installed... I realized I got usernames mixed up the other day it must have been zed x I saw early in the morning a while ago. No wonder you were confused haha
I've been in that carpark pretty much daily for the past 6 years. I've seen some of the worst parking in my life there. I try and not park near people if I can help it. Half the cars are parked across lines, at angles, and other nonsense. It seems worse on particular days of the week too. Think it must be pension day or something ..
True. Alongside grange rd is good cause people are too lazy to walk 50m and the parks are wider. I always try to pick a park where only one car can be next to mine so there's half the chance of random damage.
Prob was u, thought it was anyway.
I know that 33 too think he got inspiration from my car but failed miserably in execution, an it aint a gtr
You spotted me? Hmm when was this lol?
I did spot a nice silver 32 gtr pulling onto churchill from regency earlier on this week, was around 6am.
About a week ago on holbrooks rd, about 6 am aswell. :action-smiley-069:
Was most likely me you saw on churchill, part of my daily commute. I love dropping it down to 2nd coming down the bridge and hugging the slip lane onto regency already doing 60 that time of morning (not while the roadworks are there like they currently are)
Ah yea I thought it might have been you ;)
Haha yea you were definatly flying through when I spotted you. Sounded amazing coming into 2nd under high revs :)
I pass through there around 5pm, some people are so slow through there. Just sit in the intersection like a douche -.-
spotted plenty of skylines today in the ne suburbs -
silver 34 gtt sedan, looked very stock @ repco modbury around 10am
black r32 with big wheels on NE rd st agnes around 10:30am, pretty sure it was a GTST
navy blue r34 gtt sedan, looked stock besides exhaust, in front of me around the same time as above
white 33 gtst near TTP
black 33 on lower NE around midday near highbury tavern
and a black 34 gtt coupe on lower NE coming out dernancourt shopping centre around 4:30
Near tapleys/ grange intersection on grange road at night
not there it wouldnt have been. thurs and fri nights i was down around semaphore / taperoo / osborne area (military rd, lady gowrie drive and victoria road)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
