Middle aged blonde woman driving a White R34 GTR down Crane avenue in Coromandel Valley, just now. Have to admit I was little shocked seeing the driver after hearing the throttle round the previous corner haha
hahaha love it!!!
white 31 on fullarton rd at about 3:15 gunned it turnin onto cross road i think? and blew out a massive amount of rust coloured smoke on me :(
That would be Christine (Shane - RBWARE's wife)
Spotted a maroon s1 r33 stranded in the right hand lane on morphett road near the warradale pub this arvo, was gonna offer to push but had nowhere to pull up (and wasnt in the truck so mounting a kerb wasnt an option either unlike usual :laugh:)
Yesterday around 6pm-ish.. Drove past a white R33 2 door, P plates, look like it had black vskf wheels.. They seen my white R32, turned around and followed me for a bit. On south coast. Anyone from here?
had a nice work dinner at the "Flying Knife" at Semaphore last night....overlooking the sea.
Our waiter happened to be our own resident engineer, Mr DStirls
Awesome food Dale....and you'll have to teach me how you balance those big plates all at once :cheers:
Pics please
Never ridden a bike before and did the course on Wednesday and Thursday, picked up Ls straight after passing the course on Thursday and went to buy the bike straight after that and been riding for the past couple evening/nights and it's awesome! So much more fun than the GTR and it's only a 250cc and driving within the limits around the suburbs!
The riding gear I picked up is pretty neat too - spent just about over half of what the bike's worth. No shorts and singlet for me! :P
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
