Spotted Rodder and Fr33k at ATS this morning before i left to put the car on the dyno down at HiTech. Saw SNIPER's car, HURRYUP and also a red ferarri and a few other mint classics on my way. Couldnt believe my eyes when i saw the Ferarri just sitting there. LOL. My cars running sweet now. WOO!!!
Edited by MSTR32
midnight purple 33 (40th anniversary model, only recognised it cos i looked and said "hey, its a purple version of Vu's car") by the tonsley train station this morning about 8am. Was in the etsa truck turning right into the street it was coming out of
Yay spotted! :) lol
Saw a nice blue 34gtr on Sturt Road this afternoon around 530.
Thats funny none of them spotted you
u spot them from the bus or something? i guess its easy to look down at em from that height we all cant ride in such fine vehicles as the mecerdes 446xpress and huffy bike
maybe you should create a guide so they know exactly how to modify their car to impress you to brighten your boring trip and get it removed from the road permanently all at the same time. step 1 cut cheaper car in half (how about a pulsar), step 2 glue it to the rear of your current car. step 3 call everyone else idiots cause they can still drive theirs
Edited by Inline 6
Spotted a nice black R32 GTSt on Park Tce Salisbury around 1.00 and also a nice silver Stagea parked in the Tonkins car park on the same rd
Yeah that would have been me, i work at Tonkins in Salisbury, so any given day you will see either a silver, black or white stag parked out front! Although you might need your eyes checked because i have been driving the white 260 for the whole week! lol! Being pearl white though it does give a silverish gleam in the sun!
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
