  • Replies 118
can you pm the workshop.
About to get some work done on my skyline, there is a list of workshops to use ut there should also be a list of ones to stay well away from, this one would be at the top of the list.
take it out and stick in the farker's eye.
and whoever reckons "mistakes happen, they were busy and forgot, no harm damn, bullshit etc". you're paying these idiots good money to look after your car. not the bloke's car next to yours. so if they cant keep their eye on the prize till the jobs done, then they obviously dont value your business enough.
thats shocking.... with a gtr things need to be done properly not half assed!! i say get them to do you a few favours..e.g. freebies otherwise im sure with them doing things like that u could get them in alot of trouble
at the momoent im not going to post up there name untill i have spoken to the responsible persons.
all i can say the work shop is in the western subs and the manager is the only one who works on my car..BUT perviously they have done excellent work, above and beyond and more the price that i have paid.
and im also in the auto trade and mistakes just dont happen like this, scratch a car yes but not a spark plug in the sump of a car that is tracked and fast street driven, if that spark plug hits something its all over.
KHUNJENG, there is no more to this story buddy, i went there to get some very minor work done (idle pfc problem) and this is what i get, i dont care that they forgot to put the correct sump plug in, it is VERY poor workmanship.
That's funny only because it isnt on my car! If it was, I would not be happy :)
Mistakes like this don't just "happen". To put a spark plug would require as much effort as to put the sump plug in. If they are working under the car on a ramp, they are far more likely to catch that than the proper plug. They definately didnt put it in as a temporary measure as when they would have taken it out, the new oil would have dropped anyway! Really is no excuse, even if they couldnt find the sump plug, you wouldnt put something temporary in for risk of doing what has happened, the customer found it!
Hope you get it sorted and post up the result once you have taken any action. :)
dont worry about sending me the name then.
So you didnt even go there for a service, so why did they even have the sump plug out??
i guess it comes down to quality control and sign off once a car is completed
looks like they didnt check it or go over it before customer handover
if it was my workshop i would have someone else (who didnt do the worK) check all areas of said work and tick them on a page - to ensure somthing like this wasn't released - then once that sheet is ticked it, stick a copy under the windscreen and ring the customer saying the car is ready
maybe i should run my own workshop eh :)
i swear when i saw that pic... i was mid way through eating my rice n curry... now theres rice all over my kayboard and screen lol...
sorry to laugh... but that picture is worth a thousand words... most of them cursive (is cursive even a word? is now:D)
farkn hell.. someone tell me the workshop name
i would be raging
find out the full story first - it could have been one of the crap mecahnics on his last doing being a prick - who knows
it doesnt excuse the lack of quality controll but the workshop might not have had any idea one of their hack mecahnics did something dodogy
its obviously been done for a reason. before you all jump on your bandwagons, there is another side to this story obviously as its harder to do what was done than just replace with the existing sump plug. as for fark ups...I'd like to see any one here who hasnt farked something up before.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
