Yes Cerbera zeds don't rev quite as high although mine revs to 8500 compared to a built GTR prob 9500, peak power that day with mine that day and more revs was 438rwkw, although with stock rods and they bent. Cheap motor with mostly OEM stock parts apart from pistons, since used Scat rods and all good.
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3674357
  • Replies 241
Can we please be put out of our misery!! What's in it!!
All i can figure is that it might have a higher compression ratio than most people might think, and high lift but not too crazy duration on the camshaft, mixed together with some careful cam timing; for a nice recipe..... High comp gives good off boost power and would build response more rapidly...
I'm out of ideas, please tell us the answer, we wants to know......
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3679883
Bens been perfecting this recipe for years.... I doubt he will just "kiss and tell"... I know I wouldnt (but DAMN I wish I knew).
Go Race Pace.
Edited by Antimatter
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3680268
  • 3 weeks later...
P Zero Corsas have to be one of the worst tyres i've ever tried. Get some R comps on and you will feel the difference.. lol
Not sure what your smokin dude but they are a R comp tyre, they're not quite up to the standard of RE55S but they are much better than any street tyre out there...
So tell us about your 'experiences' with tyres, which have you tried and which would you recommend???
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3733320
  • 1 month later...
its sleeved to 86mm
if anyone is looking for a full long block everything except for timing belt area covers and cam covers. i still have one sitting here is a virgin r32 gtr block with standard head which came out of a car with 67000kms on it i bought it for a project but ended up using other bits....
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3857538
+ the rest probably. With all other parts needed for the build...
I meant 20k for the engine. I bet the rest is almost 20k too.
this is running a big single on a rb30 block gtr head.
close, except the rb29 is 447KW (612HP) and it's running on pump gas, not race gas
Edited by Tao
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3857598
I'm coming into a bit of money later this year. I just want to know how much I need to set aside. I bet it's approaching $20k
Double it and you might be getting close to the total figure needed to get these results..
But I still doubt it will be enough... :P
https://www.sau.com.au/forums/topic/206406-rb29-wow/page/7/#findComment-3858027
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
