hey all i have noticed that united petrol station have a 98 pump these days. i have not tried it but has any one and is there any way to no whether its actually 98 octane. its seems to cheap compared to bp to be true. i saw it yesturday at $1.35 a litre. thats a saving of about 15cents.
am i right in saying that my car would knock more if i put it in (as its tuned on BP 98) if it wasnt 98 octane??? just monitor it on pfc hand controller. how ever dont really want my engine being the test unit.
might google it
https://www.sau.com.au/forums/topic/206967-united-petrol-stations/
Always rumours that even though it's 98 its still going to be different to BP 98, which is what most cars (with a/m computers) are tuned to in WA. Also, always rumours of people filling up with caltex 98 & getting a knock reading every now and then. Then, always rumous of people filling up with caltex 98 & not having any sort of change at all.
ive always used bp ultimate in mine and nothing else since import. Don think i will be changing now.. even tho 10 cents or so a litre cheaper is tempting. :D .. But the sky comes first so i think i will just pay it..
Maybe if you want give it a go, fill up half a tank and see how it goes... if it runs crap then u can fill up the other half with bp ultimate and hopefully that can improve it enough till it uses it all up? ..
I know some skylines that run on Shell 95... and they seem to run ok... but for a ~10cents less a litre... is it really worth it? When the damage bill can be much higher... :P
I put some in my tank last night 134c/L car seams to be running perfectly fine will give it a thrashing tonight and see if she blows
Let me know how it runs dude. Atm I'll willing to pay 10cents extra if it betters the car in the long run though. Plus I dont think Rocko has a United servo.
I usually run mine on Caltex 98 or BP98, only had bad fuel once when the caltex had almost run out (stupid me for filling up). Have also filled up with peak 98 and not had any troubles, but I will continue to fill up from caltex cos there's 3 of them within 5 mins of me and I have a fuel card. Filling up with std unleaded or 95 isn't really worth risking or hurting ur car with.
I dont get a choice . . in karratha we have a BP but they dont have 98 . . the highest is premium . . and when i asked if they had 98 they didnt even know what it was??? RETARDS!!! So i have to use premium
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
