As per the above guys. My R33 is going to be a Street & track drift car once the motor is rebuilt etc.
Just wondering if changing the radiator is a must if im gonna be taking it to the track. Is there a big difference in temps and consistency with temp using these aluminium radiators?
Is it worth the money?
Let me know guys. Any feedback would be nice.
No.
Being aluminium doesn't make a radiator reject heat any better than being copper. It just makes it lighter.
The second consideration is the volume of coolant the radiator carries. Obviously the longer it resides in the radiator (as opposed to the motor) the more heat it can reject. Just as obviously the more coolant you carry the heavier the system.
Bottom line: Check your current system to condition. Make sure it is up to scratch. Then & only then replace it if it is marginal.
Drifting is a bit of a hard application for radiators simply because the motor is putting out reasonable amounts of power but the lack of airflow makes it hard for the radiator to function.
Edited by djr81
You also need to consider the age and condition of the plastic end tanks on the std radiators. Considering the stress that drifting etc put the car under I wouldn't be surprised if the coolant system sees higher than normal pressures.
LOL @ vid, man that was an awesome burnout until his engine blew.
considering that thing was bouncing of the limiter for such long periods of time im not surprise it overheated and BANG! :D.
what u have to remember in drift is that your car is traveling sideways, hence there isnt much airflow for your radiator to disperse the heat.
keep an eye on your water temp and if it reaches pass 120 -140deg, pull it in and let it cool down. a larger or wider radiator would improve cooling. new radiator are cleaner hence would provide better flow as well has heat dispersion. if u have a stock front bar i recommend u either get an after market one for better air flow, or even better ventilated bonnet.
AWESOME burnout!
ive found that my aluminium rad has a cooler cruise temp - around 75, down from around 80, but a hotter idle temp - from around 84 - 86-87.
Did you check these on days that were very close to each other in regards to temperature and humidity? Just to make sure the readings are consistent of course.
In fact, it might make it worse, I can't say I've tested in a radiators circumstance, but the fact is, copper is actually much better than aluminium @ dissipating heat itself, so you shouldn't actually expect an aluminium radiator to be "better" than a standard/copper one, if it is, it may be better designed than the original, or just in better general condition, therefore going aluminium should only really be on your mind if you want to make your car absolutely as light as possible.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
