Just wondering about the different types of in-car camera mount designs people have used and had experiences with. I'm curious to see what mounting methods people have found to work best for in-car footage.
There's two main styles of camera mount I've seen: clamping style (clamp on to roll bar) or suction cup camera mount (manfrotto, chasecam, etc.)
Also interested in peoples AV setups, such as the type of equipment used, e.g. camcorders, bullet cams, external mics, video recording onto SD/flash, etc.
Post some pics if you can! :)
https://www.sau.com.au/forums/topic/208608-car-camera-mounts/
  • Replies 70
nice, adz one is pretty trick. I use this one:
http://www.rivergate5speed.com/vs_camera_mount.html
it's billet alluminium, very strong and works pretty well. it wouldn't pass for door to door racing, but I've never had a problem with scrutineering at any CAMS run supersprints i've attended with it.
www.stickypod.com - ive got a pro pak - have used it at a few DECAs and works well..(even on the outside/on roofs), use it for handycams, etc..
ive also just got one of those bullet cams, arrived today..
records directly to my 80GB archos media player... the camera itself weighs about 100g and is easy to attach to anything so should be good to test..next track day.
Ive always been suss of the ones that hold the camera on the outside of the car - have you had any issues with it Aaron?
Nah steve no issues, that said its only been used outside at deca/street etc...not at an actual track day..i doubt scruitineers would like it haha
If anything i'd use the little bullet cam for outside now. Yet to test..but eager to see how it goes..
depends what sort of camera you wanna mount too...
matt what you going to use? a handycam?
Well since your GTR is wounded at the minute, throw your mount in your bag for the GP. I want to try it at PI later this month, need to see if the angle and perspective in the cabon is right before buying one. My money is that unless i havea fancy camera it will be too close to the screen and all you will see is windscreen, no dash, gear changes or steering input ????
I was going to say that one... ...I've been looking at investing in a Stickypod setup... ...But using my CC on the net still feels doggy to me...
And I haven't found any good reviews that are not linked to the web site...
Hahaha!!!... ...Gold... ...That's how I'd hang lights in the Arts Centre when I'd ran out of clamps...
What did you mount on it?
Ive got one of these HDD ones:
hey i was looking at some killer av car gear before i left autobarn,
2ch av in for bullet cams
12volt
and sd card memory.
It was about the size of a ciggy pack. i will find some pics.
i could not find the exact one but i will keep searching.
Its pretty good, bit on the large side..i reckon the smaller one would be better...expensive too..does the job for me though.
examples:
outside on scotts roof - http://au.youtube.com/watch?v=VdXCvYNUZyU
outside on scotts door - http://au.youtube.com/watch?v=r6YIGiVl9q8
outside on my rear quarter window - http://au.youtube.com/watch?v=putvYexTtFQ
inside adz(max) rear window - http://au.youtube.com/watch?v=rqwrgPg1ojg
ive used it for my DSLR as well.
on a panel..
then you can go bullet cams as well which are probably the way to go..bit on the pricey side...i'd just pick up a bulletcam kit on its own (inc mic, powersupply) and then use my DV camera to record...
http://www.helmetcamera.com.au/
http://www.dogcamsport.co.uk/DogcamPro.htm
12volt
and sd card memory.
Something like that would be sweet for me. What is a set up like that worth? Or is it cheaper to get a digi cam?
yeah no worried big fella. do you need the DV cam to go with it too? I don't need it atm. and in my 32 on the cage it's wide enough to see steering, and gear changes. :)
seriously think about switching to a DV cam mate. HDD cams and DVD cams are no good for track use. the constant vibration and knocks and bumps will destroy your camera HD. DV cam is the cheapest most reliable option for motorsport, unless you look at solid state memory like the SD of CF AV recorders (like the one trent posted) that take input from a small external camera.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
