Just wondering about the different types of in-car camera mount designs people have used and had experiences with. I'm curious to see what mounting methods people have found to work best for in-car footage.
There's two main styles of camera mount I've seen: clamping style (clamp on to roll bar) or suction cup camera mount (manfrotto, chasecam, etc.)
Also interested in peoples AV setups, such as the type of equipment used, e.g. camcorders, bullet cams, external mics, video recording onto SD/flash, etc.
Post some pics if you can! :)
https://www.sau.com.au/forums/topic/208608-car-camera-mounts/
  • Replies 70
nice, adz one is pretty trick. I use this one:
http://www.rivergate5speed.com/vs_camera_mount.html
it's billet alluminium, very strong and works pretty well. it wouldn't pass for door to door racing, but I've never had a problem with scrutineering at any CAMS run supersprints i've attended with it.
www.stickypod.com - ive got a pro pak - have used it at a few DECAs and works well..(even on the outside/on roofs), use it for handycams, etc..
ive also just got one of those bullet cams, arrived today..
records directly to my 80GB archos media player... the camera itself weighs about 100g and is easy to attach to anything so should be good to test..next track day.
Ive always been suss of the ones that hold the camera on the outside of the car - have you had any issues with it Aaron?
Nah steve no issues, that said its only been used outside at deca/street etc...not at an actual track day..i doubt scruitineers would like it haha
If anything i'd use the little bullet cam for outside now. Yet to test..but eager to see how it goes..
depends what sort of camera you wanna mount too...
matt what you going to use? a handycam?
Well since your GTR is wounded at the minute, throw your mount in your bag for the GP. I want to try it at PI later this month, need to see if the angle and perspective in the cabon is right before buying one. My money is that unless i havea fancy camera it will be too close to the screen and all you will see is windscreen, no dash, gear changes or steering input ????
I was going to say that one... ...I've been looking at investing in a Stickypod setup... ...But using my CC on the net still feels doggy to me...
And I haven't found any good reviews that are not linked to the web site...
Hahaha!!!... ...Gold... ...That's how I'd hang lights in the Arts Centre when I'd ran out of clamps...
What did you mount on it?
Ive got one of these HDD ones:
hey i was looking at some killer av car gear before i left autobarn,
2ch av in for bullet cams
12volt
and sd card memory.
It was about the size of a ciggy pack. i will find some pics.
i could not find the exact one but i will keep searching.
Its pretty good, bit on the large side..i reckon the smaller one would be better...expensive too..does the job for me though.
examples:
outside on scotts roof - http://au.youtube.com/watch?v=VdXCvYNUZyU
outside on scotts door - http://au.youtube.com/watch?v=r6YIGiVl9q8
outside on my rear quarter window - http://au.youtube.com/watch?v=putvYexTtFQ
inside adz(max) rear window - http://au.youtube.com/watch?v=rqwrgPg1ojg
ive used it for my DSLR as well.
on a panel..
then you can go bullet cams as well which are probably the way to go..bit on the pricey side...i'd just pick up a bulletcam kit on its own (inc mic, powersupply) and then use my DV camera to record...
http://www.helmetcamera.com.au/
http://www.dogcamsport.co.uk/DogcamPro.htm
12volt
and sd card memory.
Something like that would be sweet for me. What is a set up like that worth? Or is it cheaper to get a digi cam?
yeah no worried big fella. do you need the DV cam to go with it too? I don't need it atm. and in my 32 on the cage it's wide enough to see steering, and gear changes. :)
seriously think about switching to a DV cam mate. HDD cams and DVD cams are no good for track use. the constant vibration and knocks and bumps will destroy your camera HD. DV cam is the cheapest most reliable option for motorsport, unless you look at solid state memory like the SD of CF AV recorders (like the one trent posted) that take input from a small external camera.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
