[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
OK
My shafts haven't arrived yet.
The photo's attached are of the ACPT Carbon shaft.
I was sent these pic's and the shaft comes with all of the new adapters and fittings as confirmed by JAMES of APCT.
Addvantages:
  • one piece design
  • stronger shaft and fittings to match
  • but still flexes and therefore will transmits less shock loads to the gearbox and diff
  • approximatly half the weigth of the std. steel shafts, this lighter recipricating mass will provide better revibility and response (everyone, that has fitted one, swears by them)
cheers Phil.
post-3052-1207191259_thumb.jpgpost-3052-1207191288_thumb.jpgpost-3052-1207191300_thumb.jpgpost-3052-1207191336_thumb.jpgpost-3052-1207191419_thumb.jpgpost-3052-1207191440_thumb.jpgpost-3052-1207191472_thumb.jpgpost-3052-1207191526_thumb.jpg
Edited by GTR STI
Thanks for posting those photos Phil...
Looks like a carbon sleeved metal shaft. I'm still interested.
its not made of metal,
but think about it.. you cant have carbon joints can you? so there is two metal ends on a carbon shaft.
now if your wondering about reliability... some very very fast drag cars use these shafts in the uk and do not have problems..
you dont have an exact weight for one these do you ? as i have been looking at the TORQline shafts they are 5.9kg but for the price of these they are very tempting
they are pretty much the same weight. 5-6kg's
Have other ppl on SAU used these brand prop shafts?
How much power do they run?
How long have they had them in?
What motorsport do they do?
Depending on answers - add me to the list.
There are many people running these shafts,
i cant quiet get the sepcs on it but i think the mines r34 uses acpt made shaft,
Trust/Hks and alot of big tuning shops in japan sell re branded acpt shafts,
Acpt supplied nismo for the r34 Ztune.
is that enough for you?
You can also find Justin Fox on the forum and ask him about the one he's using.
With a few more people this can be underway!
Cheers
Andrew
Edited by Angus Smart
Indy from IS Motor Racing fitted my one. When we fitted it up there was a situation where we weren't sure if it fit right or not. A quick email (with pics) to and fro between myself and ACPT and all was sorted (all we had to do was have faith and tighten up the main bolts all the way).
I can't tell if the shaft made any difference to the car as I got a whole lot of modifications done at the same time.
Some pictures:
Greenline list a TRUST ACPT CARBON SHAFT, 7.4kg (normal 14.9kg) rated to 14000rpm and 350+km/hr, that looks like the one in Justins pics.
(edit; it looks like the one posted by GTR STI, with a sort of ribbed appearance and a resin type colour, whilst justins one looks black and doesnt appear ribbed. can anyone explain why they look different?)
If this is the same shaft as your group buy, then count me IN.
The best part is that greenline lists it at AUD $3750, or USD $3550, which makes the group buy seem extremely attractive.
Edited by SLY33
They are all acpt, i think that photo phil posted is a common one they send out as i have seen them on the uk forum also..
And a reminder, for an extra 100us you can get a shaft that will handle 2000ft pounds of torque compared to the 1400us 1000ft pounds..
As for payment, as soon as i can get 10 people confirmed i will start collecting money to get it off to james as acpt!
Cheers
Andrew
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
