[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
I have payment from
Willo, Arep3, And sly33 and one other :banana: the later has showed up but dont have any discription yet.
I'm still awaiting a reply from Sts, but it turn he is probably waiting for one from Acpt
Cheers!
Edited by Angus Smart
Hey guys ,thanks to those who've made it quick and easy! I'm currently only waiting on 4 more people to get in with their payment.
hopefully this week i will send off the money and we'll be looking at around 4 weeks untill delivery.... this all depending on how busy they are at ACPT.
Will keep you guys posted when i place the order!
Cheers
Andrew
Sweet, hopefully i'll get it all off this week then. i'll just go ahead when you have all the details for me. should be friday at the latest!
Mine wont be fitted for a while... typical big hp 3rd gear syndrome..... "gear go POP" :P
And i still have an engineless car. dont have the slightest idea of when its coming or where my motor is.... Sl%d$^&z% imports not so good...
My syncros are going so I ordered the 5 speed kit from greenline...now the CF shaft, then more clutches for the transfer case, then shim the diff. I'm doing the lot at once....Maybe I should just wait and buy an R35 lol :(
My thats a long shaft you have! check your pm too Dr R.. and let me know what you think.
payment has been sent today! so we're underway!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
