[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
I have payment from
Willo, Arep3, And sly33 and one other :banana: the later has showed up but dont have any discription yet.
I'm still awaiting a reply from Sts, but it turn he is probably waiting for one from Acpt
Cheers!
Edited by Angus Smart
Hey guys ,thanks to those who've made it quick and easy! I'm currently only waiting on 4 more people to get in with their payment.
hopefully this week i will send off the money and we'll be looking at around 4 weeks untill delivery.... this all depending on how busy they are at ACPT.
Will keep you guys posted when i place the order!
Cheers
Andrew
Sweet, hopefully i'll get it all off this week then. i'll just go ahead when you have all the details for me. should be friday at the latest!
Mine wont be fitted for a while... typical big hp 3rd gear syndrome..... "gear go POP" :P
And i still have an engineless car. dont have the slightest idea of when its coming or where my motor is.... Sl%d$^&z% imports not so good...
My syncros are going so I ordered the 5 speed kit from greenline...now the CF shaft, then more clutches for the transfer case, then shim the diff. I'm doing the lot at once....Maybe I should just wait and buy an R35 lol :(
My thats a long shaft you have! check your pm too Dr R.. and let me know what you think.
payment has been sent today! so we're underway!
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
