[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
Gracias...
I'd better get off my ass and try to fit this thing.
If I need to get a custom spacer made up, I'll be having words.
OS30GK: Can you please confirm that the OUTSIDE DIAMETER of the 2000hp shaft should be 9.6cm?
Can anyone else provide the correct LENGTH of the shaft, from mounting point to mounting point?
Took mine out to HKS to get an independant professional measurement and mine was 9.5 cms and thats a 2000/lbs shaft. There were couple of spots just over 9.5 and other spots just under. We took 10 measurements equal distance apart up and down the shaft.
So where to go from here???
Just measured my R32 GTR 2000 lb/ft shaft and diameter is 9.7cm.
I still have vibrations after changing to another set of wheels, so will look at re-fitting stock shaft to see if that is the cause....
MIchael
I emailed them yesterday and got this info from them.....
I have attached our assembly drawing so that you can see the length of your R33 driveshaft. With both adapters on, the driveshaft should measure out to be 44.72" from end to end. Also, 9.5cm is equaled to 3.75" which is exactly where the tube should be. I understand your concern and If you have any further questions, feel free to contact me anytime.
James Martin
ACPT Inc.
James Martin
ACPT Inc.
nice of them to send you the drawing. it might be worthwhile getting the 32 GTR one as well for merli etc so they can confirm it's all sweet before install. kind of a customer implemented QA.
yeah i second that.
crazyeeeeeeee!
mick let me know how yours is going... sounds like a balancing problem?
Edited by Angus Smart
yep it does sound like a balancing problem. Though I would have expected they have a QA process of sorts...
I have just removed tonight, can't be arsed fitting stock one, will do tomorrow and let know the results. Will be both happy and very angry if my problems go away with removal of the shaft...
Anyway chaps, heres some pics for anyone interested...
PS anyone have the assembly drawing with specs for 2000lb/ft R32 GTR shaft?
Hey guys
Okay the source of my very severe vibration in the car when travelling anything over 90-100kph (which is a major problem when the car does over 200kph on every lap of the circuit and does the drags at 200kph) is............
THE ACPT CARBON FIBRE DRIVESHAFT !
whooohooo. I'm so happy! NOT.
FFS.
First I pay a reputable garage to fit the shaft.
Then I remove it, and whooshka, problem goes away.
But just to be certain, I re-fit the CF shaft to ensure correct fitting 200% ! - Problem come back identical.
Remove again, and problem gone.
What a peice of Junk.
Very unhappy customer that wan't his money back and will throw this rubbish in the bin...
(On a side note, I can defo feel a little less responsiveness through the gears with it removed! lol)
Cheers chaps.
Mick
Hey mick,
they guys number is up above, give them a hola,
also on another note. did you get a spacer made up?? this could require balancing also??
God damn. What a friggen nightmare :D
How many of us guys have driven their cars with the shafts in? I havent driven mine yet... Still off the road!
ive driven several hundred klm's on mine no dramas yet no vibrations have done a few 180kph plus on track runs , it had a spacer made up this was the 1000ft/lbs model for a 34 GTR all good so far have not done a 7/8000rpm launch yet though thats the last test!!!
Edited by gtr13
hi again all,
i have had experience in building & balancing driveshafts from modified trucks to cars & when i received mine was dissapointed with the balance weight & the way that had been attached(photo to come) it was for that reason that i havent yet installed the shaft until i have personally balanced it at my former work.I will be removing there weight after intial balance & weld on some purpose made weights not a peice of sheet cut out & rounded to suite the shaft.
Also with a steel shaft if u go about the preparation thourougly u rarely need to use weights,& if any not of the size i have on my shaft.
OK thats my rant ,going to get pic of balance weight.
Edited by YLD-CHLD
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
