[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
Gracias...
I'd better get off my ass and try to fit this thing.
If I need to get a custom spacer made up, I'll be having words.
OS30GK: Can you please confirm that the OUTSIDE DIAMETER of the 2000hp shaft should be 9.6cm?
Can anyone else provide the correct LENGTH of the shaft, from mounting point to mounting point?
Took mine out to HKS to get an independant professional measurement and mine was 9.5 cms and thats a 2000/lbs shaft. There were couple of spots just over 9.5 and other spots just under. We took 10 measurements equal distance apart up and down the shaft.
So where to go from here???
Just measured my R32 GTR 2000 lb/ft shaft and diameter is 9.7cm.
I still have vibrations after changing to another set of wheels, so will look at re-fitting stock shaft to see if that is the cause....
MIchael
I emailed them yesterday and got this info from them.....
I have attached our assembly drawing so that you can see the length of your R33 driveshaft. With both adapters on, the driveshaft should measure out to be 44.72" from end to end. Also, 9.5cm is equaled to 3.75" which is exactly where the tube should be. I understand your concern and If you have any further questions, feel free to contact me anytime.
James Martin
ACPT Inc.
James Martin
ACPT Inc.
nice of them to send you the drawing. it might be worthwhile getting the 32 GTR one as well for merli etc so they can confirm it's all sweet before install. kind of a customer implemented QA.
yeah i second that.
crazyeeeeeeee!
mick let me know how yours is going... sounds like a balancing problem?
Edited by Angus Smart
yep it does sound like a balancing problem. Though I would have expected they have a QA process of sorts...
I have just removed tonight, can't be arsed fitting stock one, will do tomorrow and let know the results. Will be both happy and very angry if my problems go away with removal of the shaft...
Anyway chaps, heres some pics for anyone interested...
PS anyone have the assembly drawing with specs for 2000lb/ft R32 GTR shaft?
Hey guys
Okay the source of my very severe vibration in the car when travelling anything over 90-100kph (which is a major problem when the car does over 200kph on every lap of the circuit and does the drags at 200kph) is............
THE ACPT CARBON FIBRE DRIVESHAFT !
whooohooo. I'm so happy! NOT.
FFS.
First I pay a reputable garage to fit the shaft.
Then I remove it, and whooshka, problem goes away.
But just to be certain, I re-fit the CF shaft to ensure correct fitting 200% ! - Problem come back identical.
Remove again, and problem gone.
What a peice of Junk.
Very unhappy customer that wan't his money back and will throw this rubbish in the bin...
(On a side note, I can defo feel a little less responsiveness through the gears with it removed! lol)
Cheers chaps.
Mick
Hey mick,
they guys number is up above, give them a hola,
also on another note. did you get a spacer made up?? this could require balancing also??
God damn. What a friggen nightmare :D
How many of us guys have driven their cars with the shafts in? I havent driven mine yet... Still off the road!
ive driven several hundred klm's on mine no dramas yet no vibrations have done a few 180kph plus on track runs , it had a spacer made up this was the 1000ft/lbs model for a 34 GTR all good so far have not done a 7/8000rpm launch yet though thats the last test!!!
Edited by gtr13
hi again all,
i have had experience in building & balancing driveshafts from modified trucks to cars & when i received mine was dissapointed with the balance weight & the way that had been attached(photo to come) it was for that reason that i havent yet installed the shaft until i have personally balanced it at my former work.I will be removing there weight after intial balance & weld on some purpose made weights not a peice of sheet cut out & rounded to suite the shaft.
Also with a steel shaft if u go about the preparation thourougly u rarely need to use weights,& if any not of the size i have on my shaft.
OK thats my rant ,going to get pic of balance weight.
Edited by YLD-CHLD
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
