[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
  • Replies 717
Gracias...
I'd better get off my ass and try to fit this thing.
If I need to get a custom spacer made up, I'll be having words.
OS30GK: Can you please confirm that the OUTSIDE DIAMETER of the 2000hp shaft should be 9.6cm?
Can anyone else provide the correct LENGTH of the shaft, from mounting point to mounting point?
Took mine out to HKS to get an independant professional measurement and mine was 9.5 cms and thats a 2000/lbs shaft. There were couple of spots just over 9.5 and other spots just under. We took 10 measurements equal distance apart up and down the shaft.
So where to go from here???
Just measured my R32 GTR 2000 lb/ft shaft and diameter is 9.7cm.
I still have vibrations after changing to another set of wheels, so will look at re-fitting stock shaft to see if that is the cause....
MIchael
I emailed them yesterday and got this info from them.....
I have attached our assembly drawing so that you can see the length of your R33 driveshaft. With both adapters on, the driveshaft should measure out to be 44.72" from end to end. Also, 9.5cm is equaled to 3.75" which is exactly where the tube should be. I understand your concern and If you have any further questions, feel free to contact me anytime.
James Martin
ACPT Inc.
James Martin
ACPT Inc.
nice of them to send you the drawing. it might be worthwhile getting the 32 GTR one as well for merli etc so they can confirm it's all sweet before install. kind of a customer implemented QA.
yeah i second that.
crazyeeeeeeee!
mick let me know how yours is going... sounds like a balancing problem?
Edited by Angus Smart
yep it does sound like a balancing problem. Though I would have expected they have a QA process of sorts...
I have just removed tonight, can't be arsed fitting stock one, will do tomorrow and let know the results. Will be both happy and very angry if my problems go away with removal of the shaft...
Anyway chaps, heres some pics for anyone interested...
PS anyone have the assembly drawing with specs for 2000lb/ft R32 GTR shaft?
Hey guys
Okay the source of my very severe vibration in the car when travelling anything over 90-100kph (which is a major problem when the car does over 200kph on every lap of the circuit and does the drags at 200kph) is............
THE ACPT CARBON FIBRE DRIVESHAFT !
whooohooo. I'm so happy! NOT.
FFS.
First I pay a reputable garage to fit the shaft.
Then I remove it, and whooshka, problem goes away.
But just to be certain, I re-fit the CF shaft to ensure correct fitting 200% ! - Problem come back identical.
Remove again, and problem gone.
What a peice of Junk.
Very unhappy customer that wan't his money back and will throw this rubbish in the bin...
(On a side note, I can defo feel a little less responsiveness through the gears with it removed! lol)
Cheers chaps.
Mick
Hey mick,
they guys number is up above, give them a hola,
also on another note. did you get a spacer made up?? this could require balancing also??
God damn. What a friggen nightmare :D
How many of us guys have driven their cars with the shafts in? I havent driven mine yet... Still off the road!
ive driven several hundred klm's on mine no dramas yet no vibrations have done a few 180kph plus on track runs , it had a spacer made up this was the 1000ft/lbs model for a 34 GTR all good so far have not done a 7/8000rpm launch yet though thats the last test!!!
Edited by gtr13
hi again all,
i have had experience in building & balancing driveshafts from modified trucks to cars & when i received mine was dissapointed with the balance weight & the way that had been attached(photo to come) it was for that reason that i havent yet installed the shaft until i have personally balanced it at my former work.I will be removing there weight after intial balance & weld on some purpose made weights not a peice of sheet cut out & rounded to suite the shaft.
Also with a steel shaft if u go about the preparation thourougly u rarely need to use weights,& if any not of the size i have on my shaft.
OK thats my rant ,going to get pic of balance weight.
Edited by YLD-CHLD
Guest
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
