[group Buy] Acpt Carbon Fibre Tailshafts Any Model! $1400us
35 pages..... and I'm lazy to read..
Can someone post a summary of events?
Do the ACPT tailshafts provide a worthwhile performance gain or not? Any alternatives been discussed? or is it better to stick with the factory ?
  • Replies 717
I believe results were posted one person that track races their car, the result was no improvement. Money would have been better spent on a lighter clutch/flywheel to improve response.
I wouldnt buy acpt again..
go with someone else, these guys have been nothing but headache.
if my shaft causes problems its going back to acpt.
now i wasnt after performance made from the shaft, just wanted more weight taken out of the car.
How long until you put your shaft in Andrew?
Be interesting to see if you have the same issue as a few of us have had. Maybe we can get a discount for the shipping back to America
Not sure yet. will still be months off i'd imagine, dont quiet have the time and patience to work on the car at the moment. and its too cold also..
waiting on motor which was ment to be done 6 months ago..
has anyone contacted acpt yet about their unbalanced shit?
I got mine running, never tested on the track but so far it has done close to 50 dyno runs while tunning the car, no issues so far that I am aware of, 10.500RPM on most pulls.
:blush:
:laugh:
Thats A LOT of revs... whats in the engine if you don't mind me asking?
Not going to disclose too much on what is in it but I will tell you that there is a mixture between trust and hks with some personal r&d.
:P
Well mine finally passed its big test 7k rpm launch down the drag strip ran about half a dozen times this was the 1000ft/lbs model in a 34GTR this was in a 260awkw GTR not big power or anything but did handle it with no dramas no vibration all good .
Could not really do a comparison as i changed a few things since the last drag outing changed the stock suspension to HKS hipermax coilovers and fitted a titanium exhaust after removing a dodgey custom stainless job. I ran a 12.3 @115mph with the carbon shaft and i ran a 12.2 @ 116.5 mph two years ago without it !!! but i think my tyres had worn out their use by date as i haven't used them in over two years could not get any traction best 60ft was a 1.95
Is it really killing anyone by having it open? A few of us are still having issues.
Well yes - its in the GB section...
This is a section for active group buys...
Fair enough you have issues - but how long does this thread need to exist to document what everyone already knows?
Im trying to clean up for sale/GB sections etc, main reason for it all. (new forum version coming)
:mrt:
Good to hear that some of them are ok :)
Hey mate,
any chance of moving it somewhere??
  • 2 months later...
f*kin glad I read the last page. Im glad I found this page under group buys, now I feel more informed if i ever seen another groupbuy for this product from this company.
  • 1 month later...
Hey mate,
Not really... there is no "place" for this :)
Looks like its all sorted though? Been several months since posts etc etc.
Closing on that basis.
If anyone needs more info to add - then simply PM me and i can add it in.
Guest
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
