My mate's building up his RB26 N1 engine for streetable response and obviously as much power as possible. He already has GT2860R -5 turbos and Tomei 260 degree in and ex poncams. He's about to put a 2.7L JUN kit in it and the usual metal head gasket etc. etc. and just wondering what is required for the head to handle 10000rpm if required further down the track.
Obviously valve springs. What else?
Cheers
Cheers
He wont EVER need 10,000rpm with those tiny turbos.
That's why i said "if required further down the track"
It's a brand new N1 long engine. Does it still need valve guides even though the ones in it are new?
How much further?
There is little point spending mega mega $$$ on a head if its never going to be used.
Even 400rwkw CIRCUIT cars don't even use more than 8500rpm.
If its built and tuned correctly, correct turbos for the power, then you shouldn't need 10k rpm for something thats mean to be 'streetable'
Basically the whole head needs to be re-kitted for 10k rpm. Stronger everything, upgraded everything.
Your mate really needs to decide this now rather than 'if required' as its mega $$$ and effort.
350-370awkw is a very good limit really for a streetable car (and can be done with the current turbos)
Can use the stock gear in the head which is reliable and so on.
And yeah - im trying to talk ya out of it cause i think its a waste of the cashola ;)
OK I'll re-word it. How many reliable RPM will a new RB26 N1 head with tomei 260 degree poncams and tomei type A valve springs handle? The stock rev limit is about 8000 I think so it's gotta be more than that. 9000?
Tomei type A valve springs are rated to 8500rpm hence this is your safe upper limit.
if he wants it to live I'd advise sticking with 8,000rpm. stock limit is 7500 and to be honest with smallish low mounts and small cams there is no need to rev past that. for street use, sure blip it to 8,000 every now and then if you want some fun, but on the circuit, nothing will hurt your engine more than pulling big revs. look at all the reliable circuit GTRs, none of them run revs more than 8000 or 8500 tops. and many stick to around 7500. drag racing of course is another story.
brad, i was speaking directly to the Tomei engineer and the do not recommend reving past 8500 even with the full counter forged crank and rods! (maybe for drag only)
but for you top end (head) the n1 valves springs are uprated compared to standard, but you may need to uprate them again to ensure they close quick enough for those kind of revs and different retainers etc etc.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
