im in the process of buying a stagea but not sure weather to get a manual or a tiptronic can anyone help me with this.i have know idea of of the performance of a tiptronic?is it just better to gor for a manual??i hate auto's but with the tiptronic it might be ok??
can anybody help me?
cheers
https://www.sau.com.au/forums/topic/209352-tiptronic-or-manual/
what model stagea?
if its the M35, then assuming its got the same gearbox at my auto V35 (i think it is) then i can say its nothing like older auto's, its a far superior piece of kit well worth consideration
it actually sounds and feels like driving a manual, not like a normal auto
the tiptronic is a very nice piece of kit
if you're talking about an older stagea then i cannot comment
remember that 99% of the comments you will hear about autoamtics are from people with a manual car that have not driven the car/gearbox you are interested in and are just jumping in with the usual "auto's suck" comments. want some real advice? speak to someone who has driven exactly what you're after.
cheers,
Warren
  • 1 month later...
Another thing to consider, a manual box is 100x times easier and cheaper to repair if something goes wrong, those tiptronic boxes can be quite complicated so I would cringe at the cost of fixing something! If your buying a car that is reaching 10 years old, your bound to hit a few problems along the way.
  • 3 months later...
i have an auto s2 triptonic, when using the manual shifting via the gear stick i have noticed there is a slight lag in the gear change. but with the s2's dunno about s1's .. but u can opt to change gears via thumb shifts on the steering wheel (silver in pic) which are faster in selection some how .. good for straght drags .
one bad thing i have noticed about the s2 is when in drive you will have to drive like a grandma to stay off boost (2,500rpm) due to the ceramic wheel they spool faster and sooner. so any kind of pressure it will jump into boost range but thats also good if u like the response which it has.
if flat foot or the line little bit laggy until around 20-30kph then its off once it hits 100kph watch the speedo soar to 140-150 then change gears again and its off the clock
im really impressed with the power and response in the car overall, shocks a heap of holden drivers who line me up at the lights after reading my plates (rbpowa)
in the end its what u really want to drive day to day, this is not my daily driver, if it was for me personally i think i would get sick of the Manual
hope this helps in your selection, i say test drive ... find a nice manual one your willing to hand over money for ..and a auto .. your first taste or either will have your mind set i.e torque, response, lag, all that, just compare
Cheers TJ
Yeah, best to test drive both and form your own opinion for what you will use the car for..
I had a 04 Sonata ( I know, don't hang me..It was a family car) with tiptronic/selectronic (whatever they called it) and was ok in the fact you could hold in gear as long as you wanted but when you did change it still had that lag that auto's do.
It really is one of those times you have to drive both and decide for yourself..
  • 10 months later...
i have a stagea with tip tronic on wheel and the detents to shift with the leaver (+ or -).
i always owned a manual car with heavy clutches and the like (still do). but i got the s2 over the s1 stagea because of the shifting options and because the fiance only drives an auto
personally i find the wheel buttons to be useless and there is a delay in the shift. i prefer using the actual selector in the console especially on twisty roads - i guess it goes back to prefering manuals
on a hills run where you ride the boost and drive 80% (which is still damn fast) it is nice to just flick the leaver to change gears and not do accidental shift to 1st or "n" like in average autos which leave you fumbeling half way through a corner trying to look at the leaver and determine wft you just did - although you can still do the 2, 3, D, if you wish
if you wanted to push it and involve yourself in the driving experience then manual is definately the way to go. but sometimes this is just not practical for everyday use, just those select t1mes you drive 100% which realistically should only be on a track...
saving that, having an auto is handy - just put your foot down and the car will figure it out, long drives or heavy traffic are no fuss, car can be driven by anyone - i usually just leave it in "d" for drag racing mode and i find it doesn't matter
i love manuals and prefer them to a sloshamatic anyday, but the tip tronic is a good halfway point.
also i think the s2 manuals come with a guage cluster in the centre console but most auto's dont, because you need an rs4v or something, the standard rs4 comes in auto only. not having a oil pressure guage and boost guage sux and aftermarket ones tend to look a bit tacky.
best to put your bum in the seat and try yourself.
  • 11 months later...
  • 3 weeks later...
  • 3 months later...
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
