Engine is out and almost stripped.Here are some progress pics:
Nice groove in the flywheel!
The culprit!
we heard something drop when lifting the motor out.Broken engine mount :)
We have both manifolds off and some other bits.
We will have it all stripped tomorrow :(
Hopefully in the next couple of weeks,the motor will be on its way to being brought to life.I have been some what indecisive about where to send the engine to get all machined up and assembled.
Some of you might think im being a bit pedantic about the whole thing,but you when you have spent the money i have spent on this thing im sure you would be the same.
After some discussion with a fellow forum member this morning i have finally deceided to give the task to Paul(DiRTgarage) and crew.
Im sure you know of his mental 9sec quarter smasher. I told Paul that i wanted someone who will take the time to make sure everything is spot on,and not to cut corners. Paul has assured me this will happen and will look after me.So ill be making the trip up to Newie sometime soon and will be giving constant updates on the progress.
Once it's getting reassembled and you've worked out exact dollar signs it'll come together and you'll start to feel great :/
I'd love to do what you're doing, looks exciting and engrossing. You'll be having some serious fun when it's complete :/
Love the pics. Keep em coming.
good to see your using paul. he's a good bloke and im sure he'll more than look after you :/
Thanks Shane,
Happy to be on board with Dave to help out with his build. Parts are off to the machine shop next friday and will post pics of progress if Dave gives us the OK to do so.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
