OK we are in the process of taking measurements for the oil and water lines. But we cannot figure out how to run the water feed and return with a Greddy plenum installed.
Here is a pic of the inlet side of the block,can someone tell me what this bolt is? There is another one on the exhaust side under the welsh at the back of the block. Both of them are just screwed into the block.
they are the oil and water drain bolts....leave them in.
OK all, went to GCG and got the fittings,gaskets and oil drain for the turbo.
Also took measurements for all of the lines(good old string).
Took them all down to Pirtek to get all the lines and extra fittings needed. The guy there was very helpful and even custom made a few of the fittings to meet some of my clearance requirements. One thing which worries me though is the fact that the water return from the turbo to the block will have to be fed down through the exhaust manifold, Mr Pirtek man assures me the braided line will be up to the job.
Ill be using hi-temp silicone hose for the both the turbo and external head oil drains.
I also bought some bright silver engine enamel for the CAS, as against the new covers the stock finish will not cut it.
i give that line 6 months before the inside crumbles up (even if its teflon lined)
you should hard line them all now :D
heres what i did with anna's engine.
all the lines are insulated and run down the back of the motor. the 90 degree fitting on the turbo was replaced for a 130 degree for a better fit. :D
water lines are as follows, out of the standard position at the rear heater hose, thru the turbo and round the back into the throttle body out of the throttle body into the bottom hose nipple on the block.
I just took a measurement of the fitting i have on the external oil drain on the head. It sticks out 6cm. Will this hit my firewall?
is it a forged 90deg elbow?
if its not it will probably foul...pics please :P
yeah will be close. someone shold just do it with a bango instead oneday. i dont use them. cant see whats wrong with the 2 drains in the block directly below that said drain . lol.
anyway...... 7500kms later and with 6 litres in the stock sump still nothing in the catchcan :P
Just in the process of replacing the braid down through the manifold with hard lines. Do yourself a favor and do it right from the get go. The braid has limited life under those heat conditions despite being double wrapped and hard shelled with heat resistant material.
Im wrapping the manifold in heat wrap so i think it wont be as much of a problem. I am now going to route it another way anyway.
+1
My manifold is HPC'd in black and the lines were shielded and the GCG lines still hardened. My oil drain is routed away from the manifold but yet it didnt help :D (there was also a heatshield around the turbo at that time)
Dave replaced the lines (custom speedflow line) when he built the the engine and all the silver tape in the engine bay is the same heatsheild tape as the v8's run....no problems this time round.... :P
Alot more expensive but a perfect fit .....
+1
My manifold is HPC'd in black and the lines were shielded and the GCG lines still hardened. My oil drain is routed away from the manifold but yet it didnt help :) (there was also a heatshield around the turbo at that time)
Dave replaced the lines (custom speedflow line) when he built the the engine and all the silver tape in the engine bay is the same heatsheild tape as the v8's run....no problems this time round.... :D
See how i go with the wrapped manifold and and covered lines. My lines are not from GCG if that will make any difference.
P.S Love the new pic :P
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
