Why not get the stuff ceramic coated? It is so so so much better than that wrap stuff...
i was under impression that when you wrap it, all it does is keep the heat in, so it will eventually crack the steel or what ever it is you wrap. Also, if you try unwrapping it, it would have basically stuck it self to the metal, so it peels away the steel making it really fragile and weak. I just had my stuff coated, 600 for manifold, dump and exhaust housing. It is so much better.
You have gone to all the effort of doing everything else right, i think you should ceramic coat it while engine is still out :P Keeps so much more heat out of the engine bay also!
Hey mate you should look into getting a stainless steel turbo drain made up as the hose you are using will handle the temp but it will deform and knick when it heats up causing the hose to block the oil flow slightly.
I can see that oil drain being an issue from the first dyno session. Save yourself some time now and have a hard line made. Like Fineline, all my lines are going to be steel. I'll have some pics in the next week
bit late to mention it now, but since you have a forward facing plenum i would have used rb26 rocker covers which look nicer and also have the pcv hosing up the back.
That stock black hose will be replaced with lines from the Greddy oil catch can. So wont look as bad. Plus it is a 25 not a 26.I did consider the 26 covers though but decided against it.
I got that oil line from Earls. Was told it would be up to the job easy. Plus im heat wrapping the manifold so the heat will not be as intense.
Please yourself dude. they told us all the same things and we did all the same things and more to prevent issues with the braided lines but it still shit itself.
I hope yours doesnt but from personal experience you are running a risk. It cost me a turbo. :D
i would aslo guess at saying the water feed you have installed will foul on the strut tower. innner guard, whatever you want to call it.
ring ETM, he can send you a stainless oil return off the shelf to suit your aplication.
heres what i did with anna's engine...
Dave, Anna; does the AC still work in that car? Im suprised how much you've been able to bend the firewall AC fittings.
Just in the process of replacing the braid down through the manifold with hard lines.
Do you think the expansion and growth of the manifold and turbo (when hot) requires any special consideration when running hard steel lines? Ive been wondering if loops should be made to assist the tube fittings in taking load.
+1
That water feed looks way to far out :blink: Might still work... be interesting to see the final result once its in. My guess is it will be tight if it does fit...
Is that an xforce manifold?? I have heard that they crack fairly easily from people that have run them.... might pay to HPC it now while its still out of the car .... Wrapping wont help unfortunately... I have seen one die after 2 months. He HPC'd (black same as mine) the next one (ebay jobby) and it lasted over 2 years on a 400+rwkw GTR
otherwise... looking good... how long till its going in??
Yup sure does.... just a little gentle persuasion :(.... I refused to lose the air con seeing as my car is black. I bent them the first time round (majority of it) as my old tuner didnt want to be held responsible if it stopped working !! lol!!
Dave bent them a little more once the new engine was in....
Only bent to keep them away from the manifold a bit more... its all a bit of a tight fit otherwise...
P.s it didn't work at first as we forgot to plug the compressor clutch back in!! whoops!! :blink:
just wondering if anyone can help me with a problem with my rs4 s stagea?
it's surging while driving.
i already done coil packs . changed to splitfire.
using boash double platniums with gap 1.0mm. splitfire coils should jump that gap easy. no mod's only panel filter
i'm thinking air flow meter?
it seems to drive ok when cold but then if it hit a bump it starts to surg? and once it gets warm
but saying all that it comes and go's.
i also read that the soldering joints can break inside air flow meter. which would explan why it comes and go's
thanks ant
Tight fit, tell me about it! I'm just jealous i didn't have the balls to bend them like that :blink: Iv had to angle my dump pipe towards the motor to clear them, giving me about 10mm.
Cheers!
Cheers!
Yeah just bend em, DONT try and bend em back though!! They will snap... bit like copper hot water pipes etc... it hardens as soon as you move it..
Lol re the balls... I didn't really think of the ramifications if it farked up... just all guns blazing and yeah.. happy ending! thank god!!
thanks ant
LMAO thats funny as..
Back on topic it sounds like its going well, I can't wait to see power figures.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
