I thought the stock VCT was just a solenoid on the left which interacts with the head, didn't think it did anything with the cam gear. I also thought it was on the exhaust cam only, but could be completely wrong.
Reason I ask is there are full adjustable (change based on rpm) cam gears that look similar to what is on his intake cam, they are around $3000 though from what I've seen, fairly complex piece of hardware.
You are now never allowed to give advice on this forum again...
  • 4 weeks later...
Exhaust is finished, work of art! I bought 2 cats, one 5inch 400cpi Euro 4 and one 5inch 100cpi.
Still the same clutch but bought an alloy flywheel from the states.
Should have the car home very soon, just some minor things to tidy up.
Pic of the mid section.
ive always been a fan of the lobster back bends as i appreciate the workmanship involved - nothing beats it!
is there a performance gain from this though as 1 would think that a mendrel bend would flow better as it is a smooth curved edge & there is no weld edge on the inside of the pipe - i guess the difference is within a bees d1ck anyway lol
Edited by Marko R1
past the cat it makes no difference, especially at 4 inches!
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
