Saw a team wanger in a red VX Clubsport with team wang stickers on it on Cheltenham Road today around 2:30pm...
Also a yellow R34 coupe on nepean hwy in dandy at around 2:40pm
Mate of mine spotted an R34 last weekend. Blasted past him along one of the Eastlink onramps.. GOING IN THE WRONG DIRECTION
Hope it wasn't an SAU member
haha probably forgot it was paid, and didnt want to go through a toll gate lol
bit of a risk for only 50cents :P
spotted a chick drivn a stock lookn burgandy 33 round the ringwood north area, and always spot a black r32 GTR with an N1 bootlip passing me on warrandyte road everymorning has custom plates haha
Edited by urbanoperations
I spotted SKYL1N last night pulling into the BP on auburn? or burke? road in Kew.
At about 11pm, I was just cruising past, dont think you saw me.
would have been burke road. and naa i didnt see you :)
however i have seen you once at that bp and then punched a wall in jealousy at p plates on that car. haha
'R34J3T' silver R34 4-door, looked like it had chromies, driver was staring at my car as he went past, I was on Kimberley Drive in Chirnside Park waiting to turn onto Maroondah Hwy this arvo. I think it was non-turbo, got a quick glimpse of the headlights.
hey, were you the one in the 34 white sedan??? nice car :)
wife spotted an old indian/lankan driving a stockish looking black R33 on Wedensday i think she said. Somewhere near monash on the princess hwy, had SAU stickers on it
lol worng section Ni :D
but sounds like Basti either way
probably hes dad driving
:down:
its a non turbo mate, soonn to be booosted!!
lol i was thinking of the wrong car
i was thinking of asilver 34 sedan that has plates TBOJET lol
guy that goes to CREATD has it
but still get some boost in it ;)
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
