Saw a team wanger in a red VX Clubsport with team wang stickers on it on Cheltenham Road today around 2:30pm...
Also a yellow R34 coupe on nepean hwy in dandy at around 2:40pm
Mate of mine spotted an R34 last weekend. Blasted past him along one of the Eastlink onramps.. GOING IN THE WRONG DIRECTION
Hope it wasn't an SAU member
haha probably forgot it was paid, and didnt want to go through a toll gate lol
bit of a risk for only 50cents :P
spotted a chick drivn a stock lookn burgandy 33 round the ringwood north area, and always spot a black r32 GTR with an N1 bootlip passing me on warrandyte road everymorning has custom plates haha
Edited by urbanoperations
I spotted SKYL1N last night pulling into the BP on auburn? or burke? road in Kew.
At about 11pm, I was just cruising past, dont think you saw me.
would have been burke road. and naa i didnt see you :)
however i have seen you once at that bp and then punched a wall in jealousy at p plates on that car. haha
'R34J3T' silver R34 4-door, looked like it had chromies, driver was staring at my car as he went past, I was on Kimberley Drive in Chirnside Park waiting to turn onto Maroondah Hwy this arvo. I think it was non-turbo, got a quick glimpse of the headlights.
hey, were you the one in the 34 white sedan??? nice car :)
wife spotted an old indian/lankan driving a stockish looking black R33 on Wedensday i think she said. Somewhere near monash on the princess hwy, had SAU stickers on it
lol worng section Ni :D
but sounds like Basti either way
probably hes dad driving
:down:
its a non turbo mate, soonn to be booosted!!
lol i was thinking of the wrong car
i was thinking of asilver 34 sedan that has plates TBOJET lol
guy that goes to CREATD has it
but still get some boost in it ;)
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
    • So....to find any R chassis part number, get your VIN (will be something like ER33-xxxxxx for you) and go to: https://www.amayama.com/en/genuine-catalogs/nissan and enter it. From there you have access to a web version of Nissan's part system, FAST. It is a bit tricky to get used to, so maybe have a shot and post up what you think.  You can also search by general model but note in some cases your car might have different options so VIN is safest.  On diagram 211 I got 14075-75T16 for Connector, Water Hose If I search for part 14053‑21U10 that you posted, that is also a water hose but not the one bolted to the plenum and 14075‑04U00 is the fitting where the water hose goes into the block.
    • Yeah now we are talking I much prefer coolers in the front middle because it lessens the chance of a small bump to a corner stopping the whole event. I was thinking the AT cooler can move out of the radiator, delete the AT/engine coolant interwarmer and mount a separate cooler with a thermoswitch somewhere further back as is common in racing, that would be one thing. Beyond that, the engine oil cooler is an obvious one to move to the wheel arch, potentially one on each side, but unused space is an issue. I did have a earlier pic with the bumper off but it doesn't show how busy the corners are: DS is full of the auto driving sensors and PS is totally fully of windscreen washer fluid reservoir But ultimately I was hoping to keep the AC, and the water/air heat exchanger is fundamental so it is not just the radiator that needs to be in front BTW here's airflow to the rad as it ran at the track (one horn is gone now and I'll remove the lights next time):
