i reckon if you guys saw just how bad the black r32 was yesterday, youd be pretty pissed too. The guy did it just a few 100 meters down from knox police station - and i swear, he had no control whatsoever. rear went out to the right, then to the left and then ended up on the curb that separates the oncoming traffic. And really, do we need any more attention? you know what im saying?
im hearing ya man .. that guy will get pulled up later on in like 2weeks or so for random and have a cry about him being harrased by the cops cause he drives a skyline, play the innocent game.
and im not pro wet roads and heavy foot. but when i had a RWD i did it away from traffic outta sight. he's doing it in full view, should hoon report him next time. he may think twice trying to show off to his mates
kspots08 dont recall seeing you, ahhh unless you were in the 32 in opp direction? :yes:
Spotted HIGRLS in narre today
blue 32 with black bonnet in narre @ fountain gate
orange 33 in kings park
RB25DET also in narre (I think thats the plates)
That woulda been my mate. he uses this profile as well. he woulda been in a red vl turbo or a magna.
i was going for a walk with a mate about 9pm round his block and we came to a street with a black r32T doing laps up and down their street going sututut lol.. and then a grey/white r33 with sau stickers hammer it onto high st.
spotted similar looking car to mine on springval rd/hawthorn rd r33 gtst black with black rims.
then on highbury rd silver 33 gtst with black rims
then a nice yellow r34 gtt with stickers on rear of car on wellington rd.
Yeah I was thinking the same thing, we would have been leaving gym round that time.
Bugger did i spot my spotted in the wrong spotted section...fark to many options...i am blonde you know haha. ;)
Possibly had rims...only saw the ass end was peddeling like mad to catch it, but im an unfit mofo... :) and clearly had ZERO chance...
my car still has the silver uras' on them.
Havent washed the brake dust off for over a month :P
Car is spending the night at recustoms :)
yeah same wheels only get dirty again.
mines there for the next 2nights maybe three. told him i need it back by thursday *fingers crossed*
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
