yeah taking muffler out. got it back :P just a quik job in and out...
oh yeah ash advice next time you need a fuel pump changed... dont fill up your tank ! haha
lol i realised that after i filled it up lol. Did they start working on it then or did they just see the full gauge? Oh and was that you with the fluro top?
was it pound road ? or sth gippy just before the round about ? cause i remeber a white 33 come up next to me, i looked but they didnt seem to interested so i assumed just another skyline driver.
spotted AP .. LEANBAC... in noble park parked outside the tafe thingy ... was gonna put a card just to make you look over your shoulder but had none on me!
white r34 at re customs before while i was there, gold piping.
and an r33 with on big thick blue line down the middle of the car on chandler road 7.30pm thats all for today :P
I was in a new euro, not moby, my whale...and I would have waved thats for sure.
saw wayne on 3 occasions today this morning on narre cranny rd and then on ernest wanke rd this arvi while i had a L plater drive my car and then at berwick maccas where we stopped for bout 30 min and had a chat and then we saw a very very nice one of the cleanest r33's i ever seen, gave him a spotted card and gave him the run down of wat sau is and wat its about. he seemed pretty keen.
At Cue Room last night; saw a really nice r34 gtt in white with mega bodykit.
a black r33 gts-t with gt stripes on bonnet/roof/bootlid etc; had personalised plates was parked on settlement rd. Anyone on here?
Anyone else here go to cue room or bar8?
saw a yellow r34 with sau stickers goin over the freeway on narre north rd at bout lunch time then saw a blue r34 gt at waverley gardens and then a marone 33 doing a uturn at police and jacksons rd and going into shell servo
Was working down in the Nissan Engineering workshop yesterday and spotted 3 new GTR's. Had a good look at the first pilot vehicle for the Australian delievered version. :) This is the Grey coloured one that everyone keeps seeing around Dandenong. I also had a grand tour of some of the specialist equipment thats required for GTR at the dealerships for servicing, i must say, there is some serious equipment for this car, and there is a special deisgned hoist purely for the GTR that the dealerships require for their servicing.
Also had a look at the new 370Z, both nice looking pieces of machinary
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
