Was working down in the Nissan Engineering workshop yesterday and spotted 3 new GTR's. Had a good look at the first pilot vehicle for the Australian delievered version. :P This is the Grey coloured one that everyone keeps seeing around Dandenong. I also had a grand tour of some of the specialist equipment thats required for GTR at the dealerships for servicing, i must say, there is some serious equipment for this car, and there is a special deisgned hoist purely for the GTR that the dealerships require for their servicing.
Also had a look at the new 370Z, both nice looking pieces of machinary
not my spot... but a spot non the less
http://au.youtube.com/watch?v=XSFGvUoKKzs
Im certain that the RED GTR is one of the Nissan Cars, one of the 3 in the workshop is RED and has personal plates NEWGTR
saw skylin at the top end of burke rd turning where beaurepair's is. i was next to u in the blue bf xr6t waved to u but did get ur attention
Na didnt notice :)
prob buying smokes from coles or going to BP
saw wayne on 3 occasions today this morning on narre cranny rd and then on ernest wanke rd this arvi while i had a L plater drive my car and then at berwick maccas where we stopped for bout 30 min and had a chat and then we saw a very very nice one of the cleanest r33's i ever seen, gave him a spotted card and gave him the run down of wat sau is and wat its about. he seemed pretty keen.
Yeah it was a bump in to people kind of day..
As for that silver/grey R33 we saw . I cant get over he has had it for 4 years and lives in Berwick and i had hever seen it.
I have to say it was the cleanest R33 GTSt i have seen .Nice work.. :)
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
