Saw a marroon/red Series 1 Stag on Camberwell Rd heading towards the junction Wednesday around 4:30-5:00pm, flashed my foggies, got a wave back. I like the colour coded roof racks, finishes the car.
I actually see this one just about every morning, must work at Toyota or something near by.
Also saw black R34 Coupe last night at Nunawading Basketlball stadium around 7pm whilst walking my dog, very clean looking from where I was, black rims with chrome lip, looks very nice.
On the same walk about 10mins later saw a white R33 hang it out from Gyton Ave into Highbury road, hitting boost limiter or rev cut, lot of tyre noise/bitumen grinding sound.....but you didnt load it up enough, not one bit of rubber or smoke :( ...... I was hoping something :(
Black r33 'JUST8U' driving though dandenong on lonsdale st, i was behind that calais that was like a magnet on you.
Black r33 behind me at the same time QIK330 (sneaky) sorry if i frustraited you dude, was in granny mode :P
Black r33 at a red light on Cheltenham road and springvale road, black rims and silver lip around 11pm-ish
saw a black 33 tonight around 10 - 10-30, was waiting to turn right at the lights near either carrum on bonbeach station..was a mickey mouse 33 bro all done up looks mean az thought i was a s15 for a second but had to re look and saw it...was in the silver 33
day before spotted RBPOWER driving past me on hallam rd gave ya the thumbs up :P
haha thumbs up ? geez thought was gonna try grab my car lol, whole arm flew out of the car.
i forgot your online SAU tag name, so didnt do the spot
come on matty dont be like that ....
saw a Black r34 4door with SAU stickers up on a ramp in a CARYARD!
Cheltenham road Dandenong across the road from the shell service station $11,990
Thats Ash's car.. he sold it for a mitsubishi! :)
spotted a few days ago at montrose gtxr34 white thing I saw the sau stickers..you were parked behind my car the black xr6t...pretty sure ya saw me perving at your car... also who was in the blue r32 heading up mt.dandedong road at around 7 this morning I was in the xr6 again..had a lil run with you...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
