spotted a champagne colored 33 on taylors rd rowville beeped and gave the thumbs up got 1 back :banana: (had sau stickers) you live in the area?
also a black 33 on Ferntree gully rd wnet past me nice ride also
black r33 had sau stickers? i was up that way just b4
Spotted a yellow 34 gt-t going down dalton rd and turned left @ shell gave it a bit of stick sounded TUFFFFFFFFF! anyone?
hey man what car do you drive?
im around the northern burbs a lot and ill keep an eye out for you
always in lalor missus and grandparents live there
spotted a yellow R34 GTT with some tyre shop stickers(company car?) on edgars road
also seeing some r33's here and there but also a stock as a rock metallic violet bluish r32 gt4 at IGA
also, who owns the white R32 GTR thats around the corner from IGA?
Edited by GTR-boy
That was me.....lining up to get into uni. :down:
Sorry i didn't have time to react to the beep lol i looked up and saw you go past. :)
hey ali were you there on the 24/2/09?
latrobe right?
my mates told me they spotted an R32 GTR in the car park and i better go have a fap before its gone but i thought they were fkn around lol..
we were the school kids that had that seminar thingy. i dnoe, i fell asleep
haha saw you lookin. thought you had your stickers on already. thats why i wasnt sure it was u
What stickers? If sau, nope I'm not a member yet (might get on my arse and join).
i thought that r32 and the merc belongs to lindsay fox?
it does!
same tow truck that dropped it off to Autosalon a few years ago when it was in our stand
i remember because i thought "what a filthy truck for a car like that" :down:
last night saw a white r34gt at fountain gate driving around near magid drive and also a dark colour r32 with sau stickers at fountain gate maccas. gave it a little bit as they were leaving the car park lol.
yeh it would of been, i was in the little car park near the food court entrance with a few mates who had like a meet and greet with the car club that they r in. i was gonnna wave as i have seen ur car b4 but then i thought better not just incase it was sum1 that wasnt friendly. lol ne way prob see u around sumtime soon ne wayz
Yeah most likely, coz you live around the corner from my mate, but i havent seen your car there in ages :down:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
