Saw Ashneel heading down Wellington road this morning. As always, your car is looking good :-)
YAY. your car looks awesome too man. was a bit too cold to put my window down and wave lol. my mate tristian (works at NEC and lives around the corner from ya( spotted you and i was like oh ye HI lol
spotted a s14 with sau stickers at dt panels
also a white 34 there with sau stickers
i think i might have spotted ashneel turning onto bergins rd from stud rd at around 4pm
ye twas me. saw your car forgot for a minute yuo got a kit then was too late and passed ya. car looks good man. you had the whole gangsta lean happenin lol
Are you sure its a guy, im sure ive seen that car with a cute asian chick driving it.
Didn't see the driver. Just saw it come awfully close in the wet, then as I moved forward I looked in the rear view and saw the white S2000 with plates saying "TEE HEE"
It was like "tee hee hee hee I almost wrote off your car :thumbsup: " ..Nah, how about you watch where you're going mr/mrs tee-hee :)
Caramel coloured R33 GTR with standard plates but bodykit and dropped suspension on Vic Pde, East Melb at 6 pm.
Black R33 GTS on Melbourne Rd around 7 pm driven by chick. Plates [iMAQT1] lol
hehe that IMAQT1 plate number would suit a pearl white nissan - QT1 being one of Nissan colour codes for pearl white...
Lol, thanks mate. Yer was cold that morning, turbo is loving the cold air. I also saw you going the opposite direction on the way home from work.
Tristian? Not Dillon? Another person that lives near me that also works at NEC? Sheesh
lol dillon dosnt live around the corner. its his g/fs place who is my mates sister lol thats why you see his car parked there and mine every now and then.
but ye they both work at NEC and are around the corner from ya hahahaha
ye turbo really is loving the cold weather.
see ya around :thumbsup:
Hahaha oh man, i had it the wrong way round! I was under the impression that he lived near me, and his girlfriend lived a few houses down. That makes a lot more sense, thanks for clearing that up.
lol all good. ye he parks in fort of yours cause his cars been egged before parked in the street so ye safer around the corner
Yer he told me.
Well i have no objection, love having a beautiful purple GTR parked out the front of my house :-)
If i heard it's alarm go off, i'd be out there in a few seconds.
LOL u have way too much time on your hands.
Spotted a Black R34 at 8.45 this morning. Boundary Rd/Lower Dandenong Rd roundabout. Female driver. Looked hot :D
"Are you one of those boys who prefers cars to girls?"
"I'm one of those boys who can appreciate a fine body regardless of the make".
God that movie had awful dialogue....
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
