spotted by BASTI (sau card) at THE INTERNATIONAL of BRIGHTON... i work as a chef there mate.... i was told that there were many skylines at the car park... but i was busy with food tasting.... but saw a black 33 s2 ( auto) leaving... nice ride :) ...
yeah i'll be back there tomorrow night gettin smashed. mine is a s1, but s2 rear wing. the other two were my mates cars. yours isnt too bad either ;)
Saw a silver series 2 on my way to school last night.
Saw my own car almost looking like a BLACK 33 GTR in the carpark at work :P it needs a bath desperately...
and I'll be Seeing CR33M tonight, and undoubtedly B3ZA, and UNR34L...and a silver series one...at some point this weekend :P
driving home from work down bell street - about 930pm tonight - along side a white r33 s2 - very nice car! had a bit of a chat - nice guy! :P
hey howss it goin am the guy in the white r33 s2 u spotted on bell street,just joined SAU am new to it dont know much about it it but will get around it.nice lil chat bro cheers
Spotted a white R31 on Lower Dandenong Rd this afternoon being an absolute idiot! Cutting lanes, driving into the bicycle lane, speeding and swerving all over the place. Nearly wrote off about 10 cars. Very dangerous behaviour. I suspect the driver was drunk.
I tried to catch up and get their plates but I didn't want to exceed the speed limit myself.
I hope the cops impound that moron before he kills someone.
4 doors out in force today....lol
said Hi to "MANGUNE" 4 door r34 with mesh rims in Bayswater....keep your rims mate they look alright!
then a quick hello to "UNR34L" purple r34 4 door on cheltenham rd followed by and introduced to "B3ZA" but he was in a s13....are you sure its a sleeper?...damn quite a fancy looking sleeper you got there...lol
its good to see SAU people out there!
yer Good to see more 4 Doors :) , Ive now decided im a fan of the weather shields after seeing yours.. lol.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
