that was lucky for him, next week wont be, there cracking down on all charges hardcore, no second chances.
there's this sneak undercover cop car. white VE looks like a security car, its got roof lights but their clear. sits in the factory's down my street and waits for the regular idiots to come flying down haha its funny to watch.
anyway, he was outside video ezy noble park last night, waiting.
funny thing is that after we pulled into a side street, about 5 other cop cars showed up and 3 went after the skyline and apparently got him as well. dunno wot he got served with.
kept seeing this green VE in prinny and on chapel st that was undercover. went to noble maccas for a bit but din see any cops there suprisingly
spotted a silver r33 gts-t series 2 with sau stickers at glenny this evening park near novotel, and just down from that a worked r32 that was white with a carbon bonnet i think.
later in my mates car dragged another silver r33 gts-t down springy road n got fkn pulled over lol cop was like a bloody ghost appearing outta nowhere. $250 later and after a strict ear bashing from a chick cop my mate was on his way again just missing out on a street racing charge
I was the one parked at glenny im pretty sure..... def not me dragging down springy though haha.
I always see that car around, around my area. There seem to be so many more undercovers now, even saw a undercover divi van once lol.
I think he is the one who pulled me over today while I was doing a U-turn after dropping my friend at clayton TAB..as there is a single line along the rd..was a good copper...he just let me know about the new road rules, and didn't give me any ticket..and bumped into him again later in the petrol station..I was stocking up ICY POLE..and gave him one of them=p Throwing me back with a lame joke "Its always hot to drive a skyline"...me--speechless!!lol
Yesterday @ 7pm saw a very nice dark grey R33 coupe on headerlea rd. (Fountain gate/narre warren)and today @ 2 pm a very sexy black R34 at bunnings in fountain gate too near the main entrance
Last Friday spotted black and white R34 coupe styled like a JDM police car plates "JDMCOP" at the McDonald's next to Moorabbin Airport, I also saw a white R35 GT-R giving it the beans when the lights turned green - Sounded like a muffled motorcycle.
Would have been funny if the JDMCOP went after him :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
