Spotted joeyjoejoejuniorshabadoo in his R33 15 mins ago! Had a chat too.
Hot looking car mate, if only there weren't any speed limits, that thing sounded lethal... :D
thanx mate! :blink:
loved the volvo, looked mint!
spoted a cop car, got a canary :bunny:.
1.too Low
2.Boost Control
3.Fmic and Pod
Got pulled over for being too low but slowly things just kept popping up,well but the coper was not a bad bloke.not like others
when they see a skyline they just wana eat you up,NO FINE,just told me too cover the pod,bypass the boost and lift it up a bit
God Bless Coilovers.
Edited by Shanu
followed a white 34 about 10pm last night in geelong going down devo (if youre here, your drivers taillight is out)
also followed a black/grey (was a bit too dark to tell) 32 on my way home last night in geelong near botanical gardens.
Edited by stealth-ish
spotted lswturbo in sunshine.. i was in my is250 ur car sounded good ! ;)
thanks mate, think i was quite bugged that day so probably wasn't paying to much attention to surroundings. Catch ya next time.. maybe on the next cruise. :D
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
