not too sure man, u gotta ask Matt (Femno on these forums, he works there)..i havent tuned there but did do a run for about 60 bucks a while back
I'm letting matt tune my car since he built it all. I'm sure he will do a good job. Will let you know how he does
haha thanks :( bit of a Bleach fan... can u tell ????? :laugh:
i'm thinking about putting a Bleach sticker on the STAG
Me too :banana: although I think a big bleach sticker in-lieu of a work shop sticker or nothing at all would look quite ricey! :3some:
Spotted WANZI earlier tonight on the Monash, came on from Stud Rd I think... I was the little white Excel in front of you going through Narre Warren until you took the Narre Warren exit :P
Was heading to krispy Kreme I go there every tues night wit mates
Was overtaken by a black r33 gtr on the Wellington Ed exit off the monash tonight. Then along springvale road spotted an sau sticker on a silver r34 heading down springvale road. Also saw a white r32 gtr, black r32 gtst and a grey r32 gts while at krispy kreme tonight
spotted an R32 GTST last ight around 8pm on edgars. had SAU stickers
then an R32 GTR, white at about 8:23
then an R32 GTR? had a badge and wider guards, as well as a rear diffuser. but a bomex front bar? around 8:30, same spot
cool, he knows his stuff, look forward to see how much u make,,if ur car's still there on monday then i guess i'll b spotting it again lol,,takin the car back to get a couple more things done
Spotted unmarked cop car at my mate's work getting some work done on it
I do have more pics
:D
also spotted a white r33 GTR with white wheels on warrandyte rd ringwood just near the Quix Mobil at about 2.45ish
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
