hey mate we are both running rb25s with 3540s. If you ever need some work done call Ben on 0433 270 360 he is a sick engine builder and the best tuner. We have both had our cars on the road for years without a fault or failure, so I HIGHLY recommend him
Nice, the build im about to start will involve a 3582r so i should be up to your speed by the time its done, what else have you guys done internally?
/and/ a black 33 with a low profile rear wing on the ring road greensborough to dalton road... /and/ a silver 34 with no rear wing and body kit on the ring road near tullamarine exit heading west bound. Is there a limit to how many you can spot? :banana:
no, but after a while you'll only bother to post up the cars with sau stickers. there are just too many r33's out there
Spotted a Silver R34 with no rear wing on main road in Eltham this evening
Are you another Eltham member? :down: I don't see that many Skylines around.. except a four door R34 always parked near Autobarn!
I've driven beside a few SAU people before that don't look because I don't have an SAU sticker haha :down: no love :P
Car is done man. Made 280kw on the safe tune :P
Well done man, wouild hav stayed to watch your run, but had a 21st to head off to that night,,how much boost did u run?
burgandy r33 2 cars behind me on middleborough road - you turned onto the eastern freeway and i kept going straight - saw SAU stickers as u turned >,<
Sounds like me,,drive a lot around there..but i dnt have any sau stickers lol
On City Rd, Southbank tonight, spotted what must be the new Ford Falcon GT-R Taxi! The sunlight means it's not as visible in the photo as in real life, but it's certainly a GT-R badge on there :)
Spotted GTS-T Sedan on the Hume Hwy bout 2.30pm heading 2wards ring rd. i was in a big white truck goin da other way
lol no way i saw ya then bud lol
me and my dad were taking his 68 rs camaro (was behind me) to get it rwc at a friends workshop
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
