that would of been me :( parked yeh?
i work in helen road
Yup parked :( I drive past there to and from work every day. Always see a couple of R33's parked along that strip of shops.. and the black S15 is always in the same spot haha.
Last night was driving home about 2am along Springvale Rd heading north. Got to the Ferntree Gully Rd lights and there were four R31's having some fun off all the lights.
Spoke to one of the guys at the lights outside Glenny and he said all of them just got done along Princess :nyaanyaa:
No surprise to me..
Why do people continuously go there knowing it's a hot spot. Or do they go there BECAUSE it's a hot spot.
yo that was me :P
Oh sick! Only if you had your SAU stickers, I woulda stopped and had a chat :blink::P
But man... On the way down, was like 1 level from the bottom, I scraped my lip going down the ramp lol....
shush. that accident still there where you are? looked big
Yeah man, I was heading to Springvale before, I saw the cops blocked both sides of the road, I thought it was like a booze/defect station lol, so I went down Boundary Rd, and when I was heading back, they actually blocked it from the lights.
Do you know what happened?
Yea saw that too. Tried looking down the road butdidnt see anything
white r33 series one on springvale rd near ftg intersection. had pink plates but couldnt read them
yeah ive seen a r33 with pink plates too around the area a lot more now. SLDR-33 are the plates i believe
surprised i havent seen you around the area.
silver 32 GTS with blue wiper arms, sprayed blue calipers and rotor hats on Kings Rd in Taylors Lakes heading towards Watergardens, I was the guy next to you in the 32R. Where was the 32 love?? I gave you a look and "the nod" and you looked the other way. Fricken Douche! lol Kids these days I dunno
Spotted ITSANR burgandy 32 gtr on cheltenham road the other day looked clean mate gud job
Beza at shell servo corner warrigal rd, prinny hwy last night...no car tho
GTXR34 going through chelsea...clean grey 4 door 34
JDMCOP pulled over on prinny hwy by Melb Highway Patrol and camera crew :)
yellow 34 on wells road headin towards chelsea heights area
Plenty of skylines gettin around this week for sure, been hidden recently
Spotted a grey 32 when heading back from yesterdays Around the bay ferry cruise
as i was come ing in to Frankston.
Had a SAU sticker .I know him just cant think of his hame off hand.
Came on the Marysville cruise with us..
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
