Just spotted RB26T at the 1000 steps. That's one clean R32 mate, i like!
lol just went to post spotted a white 34 at 1000 steps 2day,
bit too late to park in ya bay for closer look cause i already missed the entry..
Spotted UNR33L today driving off after finishing work I assume. Had someone in the passenger seat I think?
I was driving the opposite way past you just as you took off from where you park.. was going to honk but didn't think you'd realise because I was driving the Commodore today!
TJ on westall rd and then turning onto cheltenham. saw you behind me most of the way, but you didn't respond to honks when you passed me you bastard.
LOL
Ironically got spotted by charles later on, but didnt see him. dude if you see this, thats my new number. i barely use the old one
Maybe I was following you home again :blush:
Lols, anyway number added :P
OMFG! You're stalking me!
And yeah I did, the f*cker held me up for ages. So I honked and road raged out my window. Didn't see you though?
LOL
i work at the mechanics across the road from where you pulled out! i just heard a horn then looked out that way and saw it was you haha
which area? i was around SE / knox suburbs all day today cos of TAFE in the morning
friday is my day off work :cheers:
Saw a white r33 series 2 gtst thrashing the shit out of their car going from Ferntree Gully Road onto Burwood hwy in FTG around 9:30pm I think.
You cant turn from ferntree gully road onto burwood hwy, they run parallel to each other :cheers:
LOL
Oh yeah, I think you mentioned once before. The radiator place?
My '34 has very loud horns :cheers:
friday is my day off work :huh:
Oh haha I meant Thursday evening as you were leaving work, you were just pulling out of your parking spot where I always see your car lol. First time I've had a spotting of the driver :cheers:
There was a white R34 coupe a few cars behind me on St Helena Rd up to Karingal Rd in Eltham at about 5:45pm. Don't see many around close to my area on my daily journey to and from work.. anyone from here?
My '34 has very loud horns :P
nah not the radiator place the mechanics there...its a Repco workshop.
the radiator guy isnt there anymore. been gone for about 6 months
Oh haha I meant Thursday evening as you were leaving work, you were just pulling out of your parking spot where I always see your car lol. First time I've had a spotting of the driver :P
Ah yeh finish at 10 on thursdays most likely my lunch break :) i wana see your GTR! come into activ8 satelite ISP carpark haha give it a rev and ill come out :ninja:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
