Parked next to a black S1 R33 (with SAU stickers) on Southland rooftop last night.
Must've been there for a long time. I had dinner, saw a movie and when I got back to my car it was still there :/
Also... This morning around 9am I spotted a black S13 with SAU stickers turning onto Boundary Rd from Lower Dandenong Rd.
Spotted a red Supra on the Western Ring Road just before on my way home... KHOA-02 with their bonnet up... poor guy :3
Charli, i've seen you out and about about three times in the last six months!
Must live close?
My wife saw some douche bag in a silver 34 at the maccas roundabout in Taylors Lakes the other day decide to do a drift around it while it was full of traffic! kids were around as the school had let out for the day and the other cars in the roundabout all had to stop because of this tool.
Mate if you're on here I doubt you are going to own up to it but in case you are you are a spanner! oh and you can't drift too well either and that was coming from my wife!
Spotted "WANZI" out at Epping - white r34 GTT - high street (near the Cheescake Shop) - did a U-turn at one of the roud abouts.
and a black R33 GT-R pull into the Cheesecake Shop.
yep that was me, i find myself all over melbourne every weekend. in this case i overshot the first roundabout :rofl: was that u in the white 33 from the servo?
yep that was me, i find myself all over melbourne every weekend. in this case i overshot the first roundabout :( was that u in the white 33 from the servo?
Nope - I was at the cheesecake shop buying a cake for my mum's birthday :D
You wouldn't have seen my car though - I was using the the family's Daihatsu Charade.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
