What the hell? I was just giving an opinion, not laying down a commandment.
I wasn't commenting on charli's post. I didn't see what happened or read her post.
I'm with you charli. Apparently some people can't grasp the concept of "rational debate".
yeh but your opinion is impyling that its acceptable for you to comment/lag/rat people in, its a fair assumption you then take it upon yourself to be mr.right all the time. Bet everything i own you have giving it some gas in public at some point.
regardless of charli's post you can never know the circumstances leading to ones actions so any comment you make is assumed, sure they might just be a retard but perhaps their is more to it.
i have a firm grasp on it, my "argument" makes for a fair rebuttal to all the comments/reasoning you put forward. Please do enlighten me to what rationale i have missed? I dont deny their is idiots on the roads the way i see it a light pole will catch up with them sooner or later i unfortunately am forced to sponsor victoria police through taxes so they can get off their asses stop defecting some "poor" skyline and catch a real criminal for a change.
Wow, I implied all that? Rather than continue this pointless debate I'm going to ignore any future posts about this.
FYI "rational" and "rationale" are different words. Look them up.
lol not only are you pedantic about the skyline "image" or lack therefore you focus on internet spelling.
i truly am debating with a retard. awesome :P
moving on spotted green 33 sau stickers point cook.
Ok, let me clear this up for you. "Rational" means reasonable. "Rationale" means argument. I was trying to say you resort to insults and assumptions instead of calming discussing the merits of different points of view.
But you're not listening to me anyway, so never mind.
Anything said ever.
Dude, STFU.
Spotted a white R33 on Bridge road in Eltham this morning, custom wing, sides and front, turned off to go to Greensborough and I went to Diamond Creek direction.
Dude, STFU.
who the fk was talking to you?
stock gunmetal 33 @ highpoint.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
