my bf krzysiu's car :) we were at the Italian restaurant eating dinner :D
Yeap that was me serg
Yeah I saw it when I was entering the car park for the beach... Never been around there at night, its was nice and quite until a SS tried to drift around the turn over and over and over again... :D
I thought it was the other SAU member with a orange / black car
How many are there? I know of 2 now... Krzysiu one, and a guy in the SE with the nickname of "White boy" (Non turbo this one, and has SAU stickers but isn't part of the club)
